Originally posted by: Puffnstuff
With as5 a grain of rice sized drop of compound is all that you need.
And then just spread it evenly with a creditcard?
High VID for this proc. According to AS5 application instructions for an Intel Quad, the stripe or line method is correct. No need to spread it out, the weight and pressure you put on your heat sink will do that. This is to insure you do not get any trapped air bubbles.Originally posted by: Mech0z
I think it might be the thermal paste, I just made a stripe in the middle as I thought artic silver suggested. What do you guys use to even it out, a credit card?
VID is 1.30V btw
Do you have the C1E and EIST functions enabled in your bios?Originally posted by: Mech0z
The VID is swinging from 1.1625 to 1.3 all the time in Core Temp(
Originally posted by: Markfw900
I would reverse the top casefan to exhaust.
Originally posted by: Boyd117
A lot of people spread it almost paper thin across the chip
Running 9x356=3200 and hottest core after almost an hour of prime is 55c1.33Vcore.
So its deffinetly improved
That's good news, and quite an improvement over your initial posts!
Congrats!
Originally posted by: noobish
I used the thermal paste that came with the tuniq and didnt read what brand of paste is it and just slapped on it, turn out pretty bad.![]()
Originally posted by: ImperfectLink
I got my G0 q6600 to 3.1ghz stable at 1.13125V in bios. The pencil mod (Vdroop) seems to have helped me immensely in lowering the voltage settings overall.
What MB you are using?
