Originally posted by: McArra
67.03 also supports PVP, they were the first PVP enabled drivers.
However they were not the first official ones from Nvidia and anytime we are testing real issues we should stick with official drivers....
I have seen many drivers have newer numbers now and actually be older then official ones with lower numbers....Gets confusing...
Originally posted by: mdahc
Please keep the bludgeonings light...I have read and searched through the various threads concerning the 6800 series' video processor. However, I still cannot seem to get a straight answer on whether or not the PCIe 6800 standard supports PureVideo (i.e. DVD decoding and WMVHD decoding). I could have sworn that I read somewhere that it (the PCIe version only) does (not just the half-a$$ed to non-existant support of the AGP version). Is this not true?
Originally posted by: otispunkmeyer
yeah i think from all the threads and articles, i think that at the moment the only broken feature is the wmvHD decode. i mean DVD decoding is fine right? and then its up to the other guys who develope divx and xvid and other MPEG4 codecs to get there asses into gear to provide support for their codecs on nvidias hardware. so DivX and Xvid encode decode still has the possibility to happen
of course feel free to correct me
edit: oh my, they are alive!!! just installed the winDVD that came with my 6800GT, and began playing gumball 3000 the movie, cpu usage was about 35-45% on my A64 3200, this seems quite a taxing DVD,basically lots of "Handy Cam" filming (due to the nature of the film), beautiful engine notes, and lots fast paced things being filmed so i guess that makes the cpu work harder. turned on the hardware decode and wow, cpu time is down from a max of around 50, to a max of only 20. probably not as good quality wise as the NV DVD decoders but damn good all the same. roll on DIVX support!
just asking, does the hardware decode feature in WinDVD do deinterlacing by anychance? havent watched this DVD for a while, but dang it looks well sharp
However, that doesn't mean that Multimedia Center is the problem. I believe it uses Video for Windows for capturing video, rather than DirectShow like Windows Movie Maker.
ATI Multimedia Center uses DirectShow not Video for Windows. You could have a conflict or bug with the software, but I've noticed no issues with my ATI tuners using NV DVD decoders, and my HDTV Wonder (both the analog side and digital) worked fine with my 6800 and 71.24drivers using NV DVD decoders.
"Purevideo" needs supported software, so its not even used when you use ATI's MMC.
Are you sure it's not possible it defaulted to a DXVA pixel format?
DXVA is supported depending on the hardware class and graphics driver support. Provided you have driver support, DX9 class hardware supports DXVA if the calls are made. So, the banding is probably just a software/driver issue, since the different softwares are handling it differently. Graphedit should show that.
Purevideo is the combination of hardware (NV40+) and software (Supported Drivers + Supported Software) to support specific hardware features according to Nvidia.
My AIW 9700 supports hardware acceleration using NV DVD decoders for instance. If I uncheck hardware acceleration, cpu usage goes up to 27% to 35% with a typical MPEG-2 recording of SDTV, checking "hardware acceleration" drops the cpu use down to between 5% and 18% on the same file.
Is my AIW 9700pro using "purevideo"? No, but its definately using DXVA to accelerate video using Nvidias decoders as shown by the decoder properties and performance testing with similar results to my 6800.
I suspect much of Purevideo's assist will be simply due to DXVA and the shader pipeline anyway rather than the PVP itself "depending" on what chip you have. Thats probably why my ATI and Nvidia cards have similar cpu utilization on the same media using the same software...even Nvidias own DVD decoders.
I'm still confused about the encoding though.. I thought that was permanently dead.
Originally posted by: zakee00
link
i took this while playing LOTR. for some reason, printscreen didn't capture the movie playing, but i assure you, it was.
purevideo is obviously working in this pic, as my normal idle/windows temps for my GPU are 52C. CPU useage was very low, it stayed at 0% and occasionaly jumped up to 5-10% for just a second.
im using the modded 67.66 drivers, and a 6800GT@ultra speeds. I don't have nvidias decoder, and hardware acceleration was checked in the options panel, along with an effect, which should increase the CPU/GPU utilization even more
stickify this thread
BTW, has anyone tried ENCODING with their 6xxx card? I'm sure alot of people want to know about that too. Maybe add that as a question?
linky
proof
yeah, my card idles fairly low (default GT voltages btw) but it gets up to 78C load in RTHDRIBL. thats with 100% stock cooling btw.
the dvd decoding was diffenately working (<10% CPU, usually was at 0%), and i tried Step Into Liquid (1080i) today and i was getting about 60% average CPU useage (fullscreen 12x9). but, thats with a really fast proc...Winnie@ 2.65GHz.
ill see if i can pick up a more sedate dvd, maybe then ill get down to 0% cpu time, and well if that doesnt show its working i dunno what does.
windows media player 10so u played step into liquid through what? WinDVD? powerdvd?
Sorry I'm kind of getting off-topic, but I'm still having problems with my TV tuner,
or where the f@#$ the control panel for it is
