zerocool84
I'll settle this debate. Get whatever your friends have so you can play together. I wanted a PS3 cus I'm a Metal Gear fanboi but got a 360 cus that's what all my friends have.
Originally posted by: Ackmed
MGS: Rising was never an exclusive. So one can only think he was linking it to the MGS franchise, which has always been a Sony exclusive. Including MGS4. See, its not that hard if you try. But you always try to start something with me. 🙂
Originally posted by: makoto00
xbox. if i had gotten an xbox before getting a ps3, i probably would never have gotten the ps3.
Originally posted by: Hadsus
I have both. The 360 is LOUD! Very noticeable in a smallish rooms. The PS3 is silent. Especially important if you like to watch movies....I can't watch a movie on the 360. The PS3 will stream Netflix, you just need to install the appropriate media sharing/streaming program on your PC (I use PlayOn). Is the 360 cheaper? You'll need to buy a bridge, the PS3 has one bult in (and a good one I might add). And, of course, it is a blu ray player and good blu ray stand alones are almost as expensive as the PS3. On the plus side, I like all the game choices on the 360, especially Live! arcade. You really need both machines. 😀 If I had to choose one I'd go PS3 because of all the media streaming I do and I think the 360 is too loud for that.
Originally posted by: purbeast0
get both and have the best of two worlds.
then you won't have to try and justify your reasoning for buying one over the other on intenet forums.
My PS3 is pretty loud sometimes, when the fans cut on for a bit. Not sure why they come on when I'm watching a movie or streaming DiVX, it's kind of weird, but whatever, yeah, then it's not silent by any means.
But yeah, my 360 is a train all the time, my wife hates it.
Originally posted by: guy93
PS3 is God of War 3.
I install the games to my 360 HDD and it's quiet as a mouse. The newer DVD drives are quieter than the originals as well. My old Zephyr sounded like a 747, the newer one is more like a Cessna.
Originally posted by: mugs
Really though, either one will do the job acceptably as long as you don't encounter the same issues that I have with the PS3 connecting to your uPnP media server.
Yeah, instead you can claim that your opinion of which system is better than the other system is validated because you own both. You can play both sides!
So you will let a bunch of Sony and MS haters decide for you? Brilliant. :disgusted;Having issues deciding
I have zero issues with streaming media (on the PS3 and 360), and I honestly think it's because I use a wired connection. DLNA media servers are not created equally also. I use Tversity and have for over a year now without issues on the PS3 and for about a month on the 360. A bunch of my friends like using PlayOn and have very few to no issues with it as well.
Originally posted by: Dari
Don't forget to have your coffins ready. BTW, if you have a gaming-capable PC, then you already have an XBOX 360.
Most people don't have issues I think. I'm also using TVersity. I would much prefer to use a wired connection. First thing I did when I bought my house was run 4 Cat6 lines + phone and RG-6 for cable TV to all of the bedrooms except the master, the family room and the garage. Unfortunately it was darn near impossible to fish everything to the location in the master bedroom where the TV would go, so I gave up.
QFT
That's why I went PS3.
:thumbsup:
see, R Nilla knows the game.
QFT
Exactly, because Halo 3, Gears 2, Forza 2, Crackdown, and many other games are available for PC...
Wait, not they're not.
PC got Gears 1 what, a year or so after it came out on the 360? It got Halo 1 and 2, but not 3 (and it won't). I'm just trying to figure out how you all are playing these 360 exclusives on your PC's?
Both systems have their exclusives, timed or otherwise. There are a few games that only the 360 will get, there are some that 360 and PC will get, and there are some that all 3 will get.
