Sounds like a decent deal to me. Grab it!Have a chance to pick a Dell OptiPlex 9010 PC- i7 - 3.40GHz 8GB - 250GB Win 7 Pro locally. Just use for browsing music and maybe some lite video editing mostly just general computer use, I have couple smare 1TB drives for storage. Thinkt his is a good deal at $150?
You practically gave it away. Windows 10 Pro alone is over $100
Can't really see from those small photos, but the one on top (the 9010) the Green and Blue jacks are for Mic and Line Out Audio .. You also have a DVI connector, along with PS2 Keyboard and PS2 Mouse Jacks, multiple USB jacks,
1 RJ45 Data Cable Jack (NIC Card or onboard NIC), a Serial Port and a VGA Port
I can't see the photos (blocked at work) but if they are gold threaded connectors like coax connectors they are probably the antenna connections for a wi-fi card. Lots of small form factor OEM systems have add-in wifi cards.
I would say both are pretty close to the same deal and it depends on what you mean by 'farther'. 10 mins or an hour? I'd probably get the I7 because it will be easier to re-sell later since thats all most people know is that the i7 is the best. That is, if you care about reselling.
You're welcome. I saw it first on YouTube, so I can't take credit for discovering this avenue for cheap quad-core computing.Thanks V Larry and all for helping find this idea/market.
As I saw it building from new parts would been at least a couple hundred dollars more. Bottom line it was plug and play all is good.![]()
