Torn Mind
Why are making general statements in an attempt to "spook" the OP when it's all known what system is being bought and what the exact manufacturer of the PC is.You likely won't be able to overclock even with a better cpu cooler. The motherboard in that thing is likely garbage.
That in of itself is value you aren't including. Quality isn't cheap. I don't buy prebuilt because computers are a passion of mine and I can easily justify a couple hundred to have a quality build.
Also the video card is likely oem which I don't do either. I much prefer aftermarket. Quiet, cooler, better oc ing.
He has to spend ~$245, depending on tax and if he uses rebate sites and discounted gift cards, to spend on "corrections" to the PSU to match the quality of a "built" system. An upgrade to a high end PSU and cooling requires $200, tops. And he can upgrade RAM as well, whereas he'd go over $1100 if he priced out a 16GB system.
A better heatsink is a passive device that affects noise and overclocking. But for those who are satisfied with its noise level and don't care about its ability to handle overclocking, going "better" is not going to improve their utility one iota.
What's the difference in quality between the original Phanteks case and one with the CyberPowerPc branding on it? Is the logo so powerfully bad to lower the gauge of steel, sharpen the metal, de-temper the glass?
Is the MSI Bazooka in there made worse because it was put in there by a worker a CyberPowerPC instead of the buyer himself? No, for something mass produced, it is your own snobbery showing through.
The PSU, if it is the "Xtremegear" unit that often shows up in a CPP base config, is inded poor quality.
The CPU certainly is not any worse because it was prebuilt vs put in its socket by the users own hands.
Assembling together parts by yourself does not transfer anything sacred or make sacred the mass-produced printed circuit boards in a computer system. You can love building computers, but don't think the pleasure from that adrenaline and dopamine rush from building gives you have license to make irrational statements
