911paramedic
Your onion soup may have had a ton of salt too, which will pull some of the juices out. It just sounds like you overcooked it though.
and now i want to make a roast.
No thanks, I try to stay away from shoe leather.Try it.
Searing helps to seal in some of the juices so it doesn't get dry.
Did you sear it before putting in the Crock Pot? Searing helps to seal in some of the juices so it doesn't get dry.
We'll see about that.make flavor compounds that can't be made any other way.
I usually put in a half cup of beef broth, and cook for 8-12 hours. I've never had anything but moist roast.
They'll work, but you need to be mindful of not overcooking. Is it boiling on low, or just steaming? If it's dry there's only one reason - overcooked or not enough tissue.
No it doesn't.
http://en.wikipedia.org/wiki/Searing
So did Harold McGee.Yep. Alton Brown called BS on searing.
Agree.well, not in any other way that a crock pot or other braise is going to make, anyway.
Agree.
48 hour short rib is extremely popular.I bet a sou vide pot roast would be great. You'd still want to sear/brown though.
Wrong cut. You want lots of connective tissue, rump roast. 12 hours is a little too long.
No it doesn't.
