Post your SANDRA 2001 cpu / memory scores !
fkloster
4,171
Mmmmmm. Synthetic benchmarks. Wow this thread has got fkloster's name all over it! ;)
Int ALU/RAM bandwidth/s 1582
Float FPU/RAM """"""""" 1618
CPU Drystone ALU MIPPS 3376
CPU Wetstone FPU/SSE2 MFLOPS 1077/2190
ragiepew
Damn those p4 users and ther pc800 (and fkloster's pc1000 :)) ram... those mem bandwith numbers are insane.
Nox-
I had some trouble w/ Sandra 2001 + win2k also. Upon launching it would give an error and just lockup. The only thing I could do is restart the system to get it back to normal... no process kills would do anything. Anyway, all I did is download a fresh copy and install it again and it works Ok... i still get some errors but nothing that prevents me from running sandra.
NOX
4,077
ragiepew,
I don't know what the problem is, I tried reinstalling it four times and it still restarts my comp every time. I was forced to down grade to 2000. Anyway, PM me if you got any suggestions, I don?t want to pollute this thread with my problems.
Dulanic
9,968
592
<< Memory 128mb- 367/399
Man thats really really bad for PC133 (Checked your system profile) You should be atleast in the high 400s low 500s even with CLS3. Tweak your BIOS options I would say.
ahfung
1,418
I got no problem with Sandra memory bandwidth under win2000, using BX mobo.
ragiepew
My scores for an Athlon @ 1017mhz (113*9.0) and 128mb Mushkin rev2 @ 150mhz cas2:
CPU
Dhrystone: 2849mips
Whetstone: 1393mflops
Multimedia
MMX: 5735
3dnow!: 6330
Memory
ALU: 534mb/s
FPU: 624mb/s
Nox- sorry man, dont know anything else about fixing it. It still locks on me once in a while but after reinstalling it, most of the time it starts.
Alin
rsboehner
50
AMD T-Bird 900
256 MB Crucial pc133 cas2 Ram
Memory: 434/540
CPU: 2487/1233
CPU Multimedia: 5013/6081
Is it just me or should my memory scores be higher?? Does overclocking help the memory scores that much?
ArchAngel777
5,223
61
That sounds right, remember that the sandra mem benchmarks does not only do memory, but cache speed as well. So having a 1.2GHZ athlon Vs 900mhz athlon.. well the cache is a different speed./ 1.2 is faster... therefore the 1.2 will win. Another to help give higher scores is running a higher bus speed... but I would not recomend doing that.. as your HD may thrash a lot more.
XMan
49
T-Bird 700 @ 903 (9.5x95) + 256MB PC133 CAS3
CPU
2848/1257
MM
3067/4215
Memory
389/487
My memory scores seem slower than a lot of other peoples - is there a tweak or something that would get it higher?
cardart
417
Hmm.....how'd u get up to 500+mb/s?
Mine only goes up to 330mb/s max with crucial pc133 128 ram cl2
running under win me with duron 600@900 8.5*106 with kt7 raid mobo
is there a tweak to increase the mem banwidth?
Mustanggt
3,278
memory bench - 578 / 654
cpu bench - 2749 / 1378
multimedia - 6545 / 7780
112 FSB cant run system 24/7 at this FSB but sure can use it for benchmark LOL
Dan
Duron 700 @ 1083MHz
Cpu marks
ALU 3010
FPU 1482
Memory marks
ALU 500
FPU 585
Multi Media marks
Integer MMX 6038
Floating Point 7325
resinboy
1,555
speaking of memory, I just added a third DIMM( Mushkin mosel rev2pc133) Why the hell would my mem scores go down? I am running WPCREDIT, and went back in and enabled banks 5 and 6. I think I lost about 75 points from Sandra 2001. Even tried the &quot;overclockers bios&quot;( with much trepidation) and only saw a very small improvement.
Kyle
4,145
11
Tbird 1gig@1.3
256 cas2 memory
Win98se
CPU= 3634/1770
Memory= 524/591
Abit Kt7 mobo
mhan80
85
Supposingly I have Toshiba Cas 2 ram but I dont believe the place where i bought it? When i do the benchmark I get lower results when I put it at cas2 than when I put it at auto in the msi motherboard options. And I do not get even close to the results as the otehr cas 2. Is is because Im running win2000
Soccerman
lol, when looking at your benches AMDEmAll, I notice that the P4 in the CPU benches (not multimedia), the P4 cheats! it says Winstone FPU/SSE2 in there, and the FPU score simply sucks @ss (it says 895, compared to 1363 for the Athlon), but with SSE2 enabled, it's at the top.
what a cheap, piece of crap that program is, bending to Intels will like that.
Agar
93
Here's my results:
Duron 600@1035Mhz (9x115, and yes, it IS stable 24/7 at 100% load :))
256M cas-2 @153Mhz (115 + 38)
Abit kt7-raid mobo
Running win2k
-CPU-
ALU = 2911
FPU = 1433
-CPU MultiMedia-
Integer = 5850
Floating point = 6493
-MEMORY-
ALU = 557
FPU = 627
Not bad for a $80CDN chip :))
Dee67
1,034
Wow.. some of you folks have some nice memory scores..
here's mine:
1.2ghz @ 1.2ghz
cpu:
3389/1663
cpu multimedia:
6778/8254
memory :(
491/576 @ 2-2-2/133mhz :(
Little overclocking test I ran:
1.2ghz @ 1.36ghz----
cpu:
3764/1836
cpu multimedia:
7599/9256
memory:
550/646
at this config it only ran for 10 minutes before falling apart tho..
back to the old drawing board.. :)
tHa ShIzNiT
2,321
8
-=BH6 w/ Celeron 633 @ 950 MHZ (100MHZ FSB)=-
- 256 MB of SKorpRAM (Mosel Vitelic) -
CPU: 2548/1272
Multimedia: 5119/6271
Memory: 339/375
You guys think this sounds normal?
Shooters
3,100
PIII 700@933 on Asus P3V4X
128 MB of Crucial PC133 CAS2
CPU:
2524/1251
Memory:
368/450
Multimedia:
5065/6203
