DaemonTools:
Daemon Tools is the most AWESOME virtual CD drive utility EVER. DO NOT GET CAUGHT USING ANYTHING ELSE (Except Nero Image drive, because an agreement between the authors means that Daemon Tools only supports *.NRG images if Image Drive is installed too). It was the first virttual CD-ROM to PERFECTLY emulate images well enough for commercial PSX emulators to see the images as real PSX discs, and is still the best today. It not only lets people with inadequate burners run copy-protected games from perfect images (Just burn the image as a file too the disc or run from the hard drive), but it also defeats protection for non-perfecct images in regular drives (Go ahead and burn the SafeDisc protected image in a drive that doesn't support SafeDisc, and as long as Daemon Tools is running, IT WORKS!). I know it was already mentioned, but it deserves more than just that! Now it supports virtual DVD drives and allows you to customize the device name (Being the best VCDROM means the virtual hardware name gets black-listed and detected by newer games, just more proof that it's the best)
Tray Manager:
I also saw Tray Manager listed. I'm DISGUSTED when I see someone that lets their Quick Launch and Tray area fill up with crappy useless icons! All QuickLaunch icons can be put on the start menu, (so that's only one extra click for tidyness you lazy lard-asses!
) and all Tray icons (I hope you seriously don't leave more than three enabled to begin with!) can be hidden as one. Both left and right click events work on the icons in the menu, so nothing is disabled, plus (UNLIKE WinXP!) it can restore icons to the tray if Explorer crashes! Too bad it doesn't work with XP, since it IS a better Tray management utility than XP's own!
TrayKiller is another AWESOME companion. Ever installed Easy CD Creator / DirectCD? (Don't, it messes with your ASPI layer) Well, then you're familiar with the DirectCD icon that WILL NOT GO AWAY AND SERVES NO PURPOSE OTHER THAN TO BOOST ADAPTEC'S EGO! The DirectCD program must remain running for packet-writing to CDs in 9X & ME systems, but who wants something running CONSTANTLY for something you don't use constantly? Well, DCD won't even end task nicely (It times out and you have to click "End Task" again), so it's bothersome enough just to forget about it and leave it running, but NO MORE! TrayKiller gives you 1 or more customizable Tray buttons (Mine shows a checked and Xed DCD icon) that can toggle on or off multiple programs and terminate them with no complaints! I removed DCD from startup, added it to Tray Killer, and set the icons and I'm done. Now it doesn't start unless *I* tell it to and it quits with no problem. Also, it has a handy way of finding the processes to toggle on or off with a built-in function that works like a GameShark Pro: Scan while the program's open, scan after it closes, look at the possibilities and you've got it.
Anybody remember GlobalScape's CuteMX (From themakers of CuteFTP)? It died way back when Napster was first sued but it incorporated EVERYTHING Napster lacked and was probably the first non-music oriented P2P app. Well, the closest thing there is to it is
Filetopia, and it makes everything out there feel like a piece of crap! It's IRC style channels sort content like nobody's business (Go to a #Movies channel to trade movies. that simple), and was my idea before I ever even heard of Napster! Too bad it's community is still so small compared to the others, except you will quickly notice how much more of a community it really is (Like CMX)! Hopefully, this little bit of exposure will help that aspect a bit
Truely the techies filetrading app, and believe it or not, but it predates all the "BearShare, Limewire, iMesh, and Morpheus" crap. I HATE MORPHEUS! (Though I have no choice but to use it because of the droves of popularity idiotic print magazines give it).
A request:
Is there a utility that can capture text from full-screen (ALT + ENTER) DOS boxes? I remember wanting to make a NESticle "HOWTO" back in the day, but it would show garbled graphics or crash in a DOS window and Prnt Scrn doesn't work in normal DOS mode
I'll be adding links later today (No time now). Awesome thread BTW!
