Polygraph tests are so much BS
Do you think they would tell you the exact reason for failure? Seems like they would keep it to themselves. I think the terrorist bit was just a scape goat for the real issue, midget fetishes. 😛
You probably got nailed on the drug question. They gave you a BS reason so you wouldn't learn how to beat the test if you were to ever apply for a similar position again.
For top secret there's an extremely comprehensive background check, interviews with friends and neighbors, psychiatric evaluation, and a polygraph (depending on what its for there may be slight differences)
Not in all cases. Clearances of Top Secret and higher are often issued without these tests.
It depends what level you are getting. For the lowest level, commonly called public trust its basically a criminal background check.
For secret there is a comprehensive background check
"Standard" TS doesn't require a poly or psyc eval. Just an SSBI.
Poly's are only required for special circumstances or customers.
I once passed a polygraph when I lied on the control questions. The guy told me to say yes to every question as a control. The armband was cutting on my circulation and hurt really bad. He asked me if I was standing and I said yes.
The result was "It was inconclusive"
Yes, they start out usually with an EBI (extended background check), and then you go to an initial polygraph. After that you usually get a PPR (phased periodic reinvestigation) and periodic polygraphs. At least that's how it was when I was working for the man.
Jeebus.
They need to do this type of shit in order to become a cop, too.
Just recently passed one, even with some off the wall questions regarding sex with small children. I am a very even keel person though, with a resting heart rate of under 40. Just told the truth, so nothing to get me worked up about.
My money is on that with these kind of background checks they probably wouldn't reveal the real reason why you failed. I'm surprised that they gave you a reason at all. I would have expected them to only say pass or fail.
The background check probably revealed he likes to rant online about shit he shouldn't be ranting about.
Pretty much this. There's no reason to say why a person failed, even less so if it has anything to do with terrorism. That makes no sense.
A polygraph has never caught a spy. Looks like they have a 100% failure rate of detecting spies, and a pretty high rate of false positives. Completely useless.
It depends both on what govt agency, and also what position you're applying for I think. For the Social Security Administration, at least for the entry level positions (ie. claims representatives) there's no polygraph but there are a number of background checks done.
As far as I know in the US the polygraph is mainly used for govt. jobs, particularly sensitive military and also intelligence-related ones.
When you become a terrorist in 20 years, you'll remember that test and be amazed at how accurate it was.
Terrorist! *death stare*
You're way out of line there don't you think?
It didn't take 20 years it took 20 minutes. He's a terrorist now because he was denied some job for no good reason. Stupidity: Creating terrorists since 1999.
I didn't pass the test - they said I had a positive reaction to 'terrorism'.
You dimwits, you couldn't administer the damn test, and you wouldn't notice a spy even if he took the equipment from this room. Of all the things that I did potentially have a reaction to, you choose terrorism?
WTF. I'm at a loss for words.
Well, their loss. The job would involve a ton of commute anyway, and it wasn't all that great paying. It just sucks to pass all the interviews and multi-hour tests, and get denied by a fatass who probably shorted out the circuits with his fat fingers from all the burgers he has every day.
Arghghg...
haha, I failed mine for the exact same reason. Although I already had my clearance, so I just had to go back and take the test another time and I managed to pass on the 2nd go around.
The test is complete bullshit though.
edit: I think the exact question I failed on was "Have you ever committed an act of espionage against the united states of america.
Top Secret doesn't necessarily involve a polygraph.
The biggest thing they look for in a public trust clearance is money issues. I've gone through that investigation a couple times, and the only thing that ever came up was an old electricity bill that I forgot to pay after I moved and was sent to collections.
