##POLL##What sound set up do you have on your PC?
vaporware
1) Creative Labs Inspire T7700.
2) Creative Labs SoundBlaster Audigy 2 ZS
3) UnWired Wireless Headphones. <--soon to be replaced
GTaudiophile
29,767
33
1) SB Audigy Mp3+
2) Boston BA7800 x 2 = 4.1 (only using one sub and the two-way satellites from each set)
Ronin
4,563
server.counter-strike.net
I have several setups:
1. Klipsch Promedia 5.1 speakers
2. Audigy2 Platinum eX
3. Headset/mic combo
1. Altec Lansing Select 641 4.1
2. nForce2 audio (this is my mp3 server box)
1. Creative Inspire 6.1 6600's
2. Hercules Digifire 7.1
I have others, but these are the primaries
Duvie
16,215
Originally posted by: aRCeNiTe
Originally posted by: Duvie
2 speakers!!!! I don't game and don't watch movies anymore on the PC...that is what my thousands of dollars I threw into my home theater setup is for!!!! Anybody with 8 speakers around a PC and using 20" or less monitor is truly a geek!!!
You kinda sound like a geek ^^
Ha Ha Ha Ha...Wow that one was really funny...Shows your mentality. Go ask mommy and daddy if you can use the TV in the family room or does the porn on the 50" scare you????
Alptraum
1,078
1) Klipsch Promedia 2.1
2) SoundBlaster Live! Gold
I am ordering a new Audigy2 ZS with some other crap this week or next. Lol, I have had this Soundblaster since it came out (maybe 5 years). I am keeping the 2.1 set up though. I have no desire to have surround on or near my PC. I have a stand alone stereo/home theatre for that. On other systems I have various soundcars (all creative) and speakers (mainly Altec Lansing).
BoomAM
4,546
Originally posted by: apriest
Audigy 2 Platinum, sending 5.1 analog to a couple JVC amps. Primary amp upscales to 7.1 and in conjunction with a 2nd amp sends it to 11 speakers and 2 subs. 4 front speakers, 1 center, 4 side speakers, 2 rear speakers. 2nd amp controls the extended surround and a dedicated subwoofer for them. Games are pretty good on the TV, but DTS-ES DVDs are where it really shines. 1260 watts sounds pretty impressive.
Thats an impressive set-up you have there.
Whats that like then? The 7.1 SB kit. Good for games? DVD`s? Movies? or is it no better than a 5.1 system?
Dulanic
9,969
592
1) Altec Lansing 641's without a sub (It busted) and it sounds like utter crap.
2) SB Live! (No gamer, plat, anything like that its just THE original SB Live!)
Reliant
3,843
SB Live! 5.1 and some old Creative 4.1 speakers, although I only have 2 speakers hooked up due to lack of room.
Alptraum
1,078
Thats a goofy set up. Don't take that the wrong way, I consider my main HT set up goofy as well and quite like it. What are the details? You just say JVC amps. What are you using for decoding? The PC? Stand alone processor? Processor/pre-amp? Are they recievers? And why so many speakers? Just curious.
soltrain
452
z680s into an audigy 1. when i use phones, i have some sony MDR-EX70 earbuds. they're great!
however, when i hit "6 channel direct" on my speakers, i dont get my center channel - i only get it in pro logic mode. weird.
Pariah
7,357
20
1) stereo PC speakers on motherboard
2) no need for SC, all digital sound to PC speakers
3) pipe cleaners duct taped to 2 dixie paper cups for sweet set of headphones
For particularly demanding MIDI's I sometimes use the following
Audigy 2 Platinum connected to 7.1 HT using both digital and analog
Sennheiser HD600 headphones connected to live drive. Great for real audio clips.
apriest
237
www.aaronpriestphoto.com
Well? to make a long story short, I discovered the Audigy 2 doesn?t encode EAX sound etc. and send it out digitally, only out the analog ports. It can do a pass through for DVDs etc. where the sound card doesn?t decode anything, but that does no good in EAX games such as UT2003. It only sends stereo PCM out the digital ports in a game like that. So, I had a JVC RX-778V receiver. It was Dolby Digital, but no analog 5.1 inputs, and no component video switching, and only 1 S-Video input. I upgraded to a RX-8020V with Dobly ProLogic II, Dolby Digital EX & DTS-ES (both 7.1), component video switching, s-video inputs for nearly every input, and 5.1 analog inputs. The new amp came with new speakers and a larger subwoofer. So now I have an 8? 60w sub, and a 10? 100w sub. The difference between them is quite impressive. Since the extended surround (the sides of the 7.1) are not powered by this amp, and I had all these speakers and two amps, I decided, why not?! ;-) Soooo? 4 front speakers are powered by the A & B mains of the 8020 amp, as are the single center and two rears. All are 100w apiece. The larger sub is self powered and connected to the 8020. The extended surround pre-out goes into the older 778 amp, and 4 side speakers are connected to the A & B main outputs of that amp (also 100w apiece). I?m not running the 2nd amp in surround mode at all, just stereo. I hooked up the 2nd sub to the 778 amp for more bass for the extended surrounds. It works out about perfect as it is not as powerful a sub anyway. I suppose I could get REALLY creative and find a way to use the center and surround outputs of the 2nd amp, but I think it would ruin the beautiful sound field I currently have.
So, in a nutshell, in games and what not, the Audigy 2 decodes the EAX sound into 5.1, ships it to the main amp via analog lines, the main amp ?upscales? it to 7.1, and the sides are powered by the extra amp and sub. Honestly, you can?t hear much of a difference between 5.1 or 7.1 as far as the sound field goes from the Audigy 2?s decoder, but it does turn on more speakers (the sides) making the surround much more effective and louder. When watching a DTS-ES DVD from the dedicated DVD player, or from the Audigy 2 when using the pass through and digital connectors, there is a huge difference between 5.1 and 7.1, because the amp is then doing the decoding in true 7.1. I suppose EAX would really kick if I had an Audigy 2 ZS and an amp capable of 7.1 analog inputs. Which I could technically do if I fed 5.1 to the main amp and the sides to the 2nd amp on another input, such as CD. I may end up doing that. I need a real HDTV (or a projector) first though! ;-)
eriqesque
704
Terratec Aureon Space
Sadly though most of the time Iam on my T40
with 2.0 and Soundmax Digital Audio with a total power output of 1 watt WOO HOO.
cessna152
1,009
1) Logitech Z-540
1) Hercules Fotissimo III 7.1
3) Some Lucent Voice Recognition MIC my dad had... Think they used it for VOIP testing.
