Forgive me for not quoting but I'm feeling lazy
Sometime in the winter (it doesnt have to be too cold, I live right in the center of the country near st louis) when it a bit below freezing, anytime when it could be snowing, etc and open a bottle of conventional 10w-30 and a bottle of mobil 1 10w-30. The mobil one will seem like water in comparison. If my overhead cam and lifters are bathed in oil 20 seconds soon that could save a whole lot of work, not to mention getting all the bearings oiled quicker too. To me thats worth it since you know cold starts even when its not that cold, cause a lot of wear.
Actually I wasn't refering to it not mixing in the axles while driving, but instead that it will settle when you stop so that it can easily be cleaned out if you have no replacement fluid available. With conventional juice you just have an emulsion and the whole thing is wasted. So instead of just having low fluid you have no fluid
I will admit I haven't seen a whole lot of newer vehicles on the trails suck in water, but some of the older ones.... My 80 CJ5 I'm sure wouldnt handle a water crossing well right now. It just depends on how old the seals are. Dont forget that not only is there a pressure difference, but some metals like aluminum change size in really neat ways when its hot and dunked in cold water. It can be just enough to make a good seal, not seal for a couple seconds!
Never underestimate how many turbo cars there are in this country, ChryCo put out a TON of them in the 80s and it looks like they're getting more popular again. In Europe they've always been pretty popular (like 5 speeds.....lucky europeans). I was just using my car as an extreme example, but I still feel any car that doesn't use oil can benifit from it. Although its not important enough to miss any meals for I'll admit
