Originally posted by: RussianSensation
My friend bought a WD74 gig hard drive and Asus K8V motherboard last September. Neither shipped with the driver disk.
Did the motherboard come with a driver CD? The drivers for the SATA controller should be on that. And (as has been pointed out)
it should have been packaged with a floppy too.
I previously didnt have experience installing SATA on a computer and found the process to be a lot less smooth then connecting IDe drives.
I find it currently about the same as when I had to install drivers for my SCSI controller.
The point here is, even if SATA is better than IDE, the advantage of SATA over IDE is 0.00000001%.
I think you are looking in the wrong place for examples of advantages.
Now the amount of strides taken in say videocard industries when videocard companies double speed in 1 year is something to get excited about. It took hard drives 5 years or so to double performance, if that.
If you are looking at hard drive performance, then you have to also take capacity into account. An area which has exceeded just
about every other area of the industry in per year growth in the last decade.
Even now notebooks ship with 4200rpm hard drives (specs that sound like they are 10 years old)
Notebook drives are designed to run on less power, thus saving battery life. And as above, the "performance" increase
on notebook drives has been in the increased capacity over that time frame. Increasing capacity does lend to an
increase in transfer speed without having to change to a faster motor.
And how serious were the improvements made by SATA to hard drive industry in comparison to say PS2.0 in videocard industry or LCD in monitor industry or dedicated sound card in the sound industry?
The improvements from changing over to SATA are still occuring within the industry, just like all your other examples, it is not something
you can point to as having an effect overnight. We are only now starting to see drives with native (not bridged) SATA support, and that
bring NCQ and hot swap as features of the spec to the table.
Just ask yourself if SATA disappeared tomorrow, how many ppl would actually care?
A lot more than you think. Not every technology is designed from the start with the budget end-user in mind.
