Poll: MP3 Compression Bit Rate?
EglsFly
Just curious as to what everybody is using out there.
Feel free to vote and add a comment if you want to elaborate why you chose that level.
Thanks! 😎
Lossless FLAC format on my music server.
Since it's lossless I can transcode to any MP3 bitrate I want for a portable, and change my mind as often as I like without any lossy-to-lossy encoding quality drop.
For my Zen Xtra portable I transcoded the FLAC to 192 kbps average VBR (LAME -aps -extreme) using dbPowerAmp's mass conversion tool.
I have been ripping at 128K just so that when I burn CDRs for my car audio MP3 player, I can get more music on a 700MB disc. 🙂
I use 320kbps for all mp3's I get from online or wherever, but I've started to use Apple's Lossless Format for CD's. It sounds so crisp and it's as close to real as you can get. I'm thinking of converting my mp3's to AAF but idk if it'll work.
LOL, no. "Upconverting" can't magically restore information that has already been thrown away.
It doesn't work for camera images like they do on TV either. ("Can you enhance the detail on that license plate?" "Sure" (presses the magic add detail button))
I go for maximum bit rate. Quality is most important. I'm in no danger of filling my 20 gig mp3 player, so file size be damned!!
Winnar. I use q7 vorbis though, there are many other codecs than do much better than MP3 for the same filesize.
edit: on the same note, my flac 750GB raid 5 array just passed 550 GB used :shocked:
I usually rip both to q7-8 Ogg Vorbis and 256kbps CBR mp3. Yes, that means I rip twice. I rip to FLAC and 256kbps CBR mp3 for stuff I figure I'll probably need more copies of, but I can't hear the difference between q8 Vorbis and FLAC, so I usually leave FLAC alone.
Why bother with mp3 at all? Well, Ogg Vorbis decoding takes more power than mp3 decoding. This isn't a problem for my computer, of course, but it hurts battery life on my DAP.
:thumbsup: I've ripped almost all of my CDs (roughly 1,000 so far) but that only took aroung 300 GB for the FLACs and another 100 GB for the MP3 copies.
I use human-powered mirroring so I have another set of drives in the closet with a second copy of the files. That seemed a little safer in case of something like a power supply explosion.
