Yes, or close to that. hence why his friend is a ignorant moron
From wiki
In
computing,
Streaming SIMD Extensions (
SSE) is an
SIMD instruction set extension to the
x86 architecture, designed by
Intel and introduced in 1999 in their
Pentium III series of processors shortly after the appearance of
AMD's
3DNow!. SSE contains 70 new instructions, most of which work on
single precision floating point data. SIMD instructions can greatly increase performance when exactly the same operations are to be performed on multiple data objects. Typical applications are
digital signal processing and
graphics processing.
And from Cpu-world, all the extensions:
Features
- MMX instructions
- Extensions to MMX
- SSE / Streaming SIMD Extensions
- SSE2 / Streaming SIMD Extensions 2
- SSE3 / Streaming SIMD Extensions 3
- SSSE3 / Supplemental Streaming SIMD Extensions 3
- SSE4 / SSE4.1 + SSE4.2 / Streaming SIMD Extensions 4  ?
- SSE4a  ?
- AES / Advanced Encryption Standard instructions
- AVX / Advanced Vector Extensions
- AVX2 / Advanced Vector Extensions 2.0
- BMI / BMI1 + BMI2 / Bit Manipulation instructions
- SHA / Secure Hash Algorithm extensions
- F16C / 16-bit Floating-Point conversion instructions
- FMA3 / 3-operand Fused Multiply-Add instructions
- AMD64 / AMD 64-bit technology  ?
- SMT / Simultaneous MultiThreading
- EVP / Enhanced Virus Protection  ?
- AMD-V / AMD Virtualization technology
- SMAP / Supervisor Mode Access Prevention
- SMEP / Secure Mode Execution Protection
- Precision Boost
- Extended Frequency Range
