Please help diagnose my BSOD problem
futurefields
6,470
32
I honestly dont think its my cpu
Not ruling it out
I just think thats far down on the list of likely causes
I believe its more likely a software/driver conflict, RAM failing, HDD failing, PSU failing, or motherboard failing
Just from my experience... cpu's are usually one of the longer lasting components in a desktop pc
Nothing more to say really until I get home and swap the RAM back hopefullt then i can atleast get back into windows and back up files
mxnerd
6,799
1,103
Saw that you have Event id 9, iaStor error.
It could be disk error like bad sector, faulty SATA port or faulty cable.
futurefields
6,470
32
I just broke the sata connector on one of my hard drives fml
Well i got the thing to boot into Windows with one hard drive
futurefields
6,470
32
I dont know, i think i fixed my hard drive by fitting the broken piece from the hd end into the cable, and then sliding that onto the pins. Feels like contact is good didnt try and boot it yet though
futurefields
6,470
32
I reseated my cpu cooler, applied new thermal paste
Moved RAm back to slots 1 and 3
She boots with the 500gb only
The 3tb that i just broke will have to try tommorow
Reactions: mxnerd
[DHT]Osiris
17,370
16,645
You need to go component-by-component in this thing, once you get it booting back into windows, do a few hours worth of stress testing on RAM, CPU, and disk usage, see if one of them repeatedly causes a bluescreen. If I were a betting man I'd say you either have something RAM-related going wonky, or something wrong with the disk itself. If it seems isolated to the disk, but the disk itself isn't reporting issues with sectors/whatever going bad, reformat/reinstall and see if that fixes things. If not, get a new drive.
futurefields
6,470
32
When i have both hard drives connected and boot my pc up it says it cant find the desktop and i cant do anything
If i have just my c: hooked up it will let me boot into my desktop
How weird is that?
mxnerd
6,799
1,103
Windows repair sometimes will screw up the system.
Don't connect your 3TB drive at boot. Boot the system using 500GB drive, then connect the 3TB drive (hot plug) .
Launch your disk manager and see how drive letters are assigned. Might have to reassign them.
Remove drive letter from the 100MB boot partition if it's assigned a drive letter.
Use free partition manager if necessary.
http://www.easeus.com/partition-manager/epm-free.html
sm625
8,172
137
How weird is that?
You need to go into the bios and ensure that you are indeed booting off the 500gb drive.
bigboxes
42,228
12,415
I don't know why I am laughing. I had this same thing happen to me some years back and remembered that that 160GB drive was sitting on my desk. I rest my Nikon on it! LOL. I was able to just attach a sata cable to it and copy the data off. It was one of those WTF moments and why didn't they design the standard to make the connector on the hard drive female. Something not so fragile like the new USB Type C connector.
