Planning on using a holesaw. What kind of power drill should I use?
Punjab
4
Hello all! I'm planning on doing my first case mod and was thinking of using a holesaw to cut my holes for me. So here's a question for those who have used Holesaws: What kind of specs should a power drill have in order to cut through cases effectively. I'm hoping to spend $50-$75 on a new drill. Any suggestions?
Thanks
GunNut
Banned
Aug 7, 2000
162
i recommend something cordless with variabe speed, 12 volts or greater i have a black and decker firestorm , and i like it but sometimes the battery dies when i need it, Skil has a dual power source (battery and a/c).
Buffaloman57
402
Well, I use a hole saw also to cut my holes in the case 3" and 4". Make sure you use a Bi-metal hole saw as the case and frames are hard metal. As for a drill is must be a 1/2 drive drill of any kind because hole saw arbor size. Sear drills will work and if you can find it on sale there you can save alot of money. The drill doesn't have to be super duty.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,667
At that price, you'll want a variable speed 3/8" chuck cord-type drill. Make sure the hole saw mandrel will fit in the drill, otherwise rent a 1/2" chuck drill. The less expensive cordless drills don't develop enough torque to handle hole saws, particularly at low rpm's.
Use a backer board, clamp it down tight, use lots of oil. Real easy to hurt yourself or end up with fubar'd parts.
NEWKILLA
3,589
is jhhnn the only one using oil? get good cutting oil
get the 1/2 inch drill and hold on tight, clamp your work tight
and most of all have some fun,
killa
Punjab
4
Thanks for the tips! I'm now thinking of getting a Skil 1/2" 4 amp 800rpm corded drill. That should work right?
GunNut
Banned
Aug 7, 2000
162
no mat what you buy, make sure it is one you can use for other projects. I bought a cheap one speed 3/8 drill several years ago. It is grat for drilling, but if i want to use it for screws forget about it, it is too fast for screws, i hate it now.
Mday
18,646
if you are going to cut metal, as long as the drill works it's fine. what you need is torque. anyway, metal cutting with a holesaw is a SLOW and tedious job. run it at a low RPM, and press down firm, but not too hard. $50 to $75 is a good price to start at. as long as you are getting a corded drill, double that if you want cordless.
a good holesaw for a 120mm fan (4.6 inches or so) would cost $20. i bought a 2.25" holesaw and cut a clover for my 120mm fans. months later when i got my hands on a jigsaw, i finished the cutting =P
don't forget to get cutting oil. libricate that saw and cutting material =)
4 amps is good =)
Punjab
4
Just want to update (aka brag) everyone interested in this thread about my new power drill acquisition. I just got me a Skill 5.0 amp 800rpm corded for $50! Not bad as I was shooting for 4.0amps for that price. :) Now all I need is some more cash for holesaws, arbors, oil, and clamps. :D Can't wait to get to work!
ASK THE COMMUNITY
TRENDING THREADS
