Planar 20" LCD black $798.36 shipped @ Dell Home
Originally posted by: mchammer187
i just ordered an 1800FP for $385 after FATCASH 🙂
IMO it is a better deal than a 19" because 19" LCD are just 1" bigger with no upgrade in screen real estate
the screen size of the 19" monitor is roughly 11.4% bigger in size
the 1800fp has a thin bezel as well
if you were to get one I would go with a 20" that does 1600x1200 or a 17/18 with good specs
Can the 1800fp do portrait mode? I know the 1901fp does.
what is portrait is that where you keep the same as the native res but when you change your size to say 640x480 than it is centered with black around?
I have no idea if it does or not but in what situation would you want to use that in but if that that feature is important to you than by all means go with the 1901 fp
I'm sure that you already know this but that is a KILLER DEAL, barely over $700 and you can have a DUAL 18" LCD setup.
Back in the day, 17" LCD's were king and cost $1,500 ... my how technology and times have changed.
i need help deciding on which monitor to buy. all i do is play games and watch movies on my computer. which one should i buy?
PLANAR
PX171M-BK
or
VIEWSONIC
VP171b
thanks for the help.
steve
PLANAR
PX171M-BK
or
VIEWSONIC
VP171b
steve
what are the prices on each because if they cost relatively the same as an 1800FP I would go for that
without specs it is hard to tell
Bought a Dell 1800FP earlier this year and have been very happy with it. Think I'm going with the 1901FP this time and wait for the 20" LCD to come down a little more before I upgrade again.
yeah I know I would go dual but I have a 2000FP for myself already and this LCD is going to my brother who is on a crappy 17" non flat CRT
quite a big jump I dont think he has the space either since he is living in a dorm
great deal and dont forget Fatcash the extra 3% is like an extra $15 - 20
I got an email from dell SB a couple days ago. It didnt have a general 10% off coupon though, it just had 10% off of inspiron and lattitude notebooks. I am signed up to emails from dell SB, so did you guys get a different mail then I did?
I would like to go for the 1800FP with 35 off 400, 10% regular discount and the 10% dell SB stackable on top.
Anyone have any input?
Actually if anyone has an extra one of those coupons I could put it to good use right away!
email me at corystockton@yahoo.com...
Thanks!
Portrait mode is where you rotate the screen so that the length is now the longer side. See here
no, im pretty sure it does not have portrait mode then
which one would be best for games?
PLANAR
PX171M-BK
Diagonal Size: 17"
Viewable Size: 17"
Display Type: Active Matrix TFT Flat Panel Display
Display Type: Flat panel display / TFT active matrix
Depth: 21.6 cm
Depth: 8.5"
Features: 16 ms response time, 56-77 Hz refresh rate, Quad stand with height, pivot, swivel, and tilt adjustment, Kensington® Security slot, Anti-glare coating, and multi-language OSD
Features: Locking device keyhole (cable lock)
Height: 14.1"
Height: 35.8 cm
Weight: 14.5 lbs
Weight: 6.6 kg
Width: 14.8"
Width: 37.6 cm
Image Max H-View Angle: 140
Image Max H-View Angle: 140°
Image Max V-View Angle: 140
Image Max V-View Angle: 140°
Analog Video Signal: RGB
Audio Output: Integrated stereo speakers with 1W/channel
Audio Output: Speaker(s) - integrated
Built-in Devices: Stereo speakers
Cable(s) included: 1 x 15-pin D-sub VGA display cable, 1 x 24-pin DVI cable, 1 x standard power cable, 1 x audio cable
Color Support: 16.7 mn colors
Color Support: 24-bit (16.7M colors)
Compliant Standards: FCC Class B certified, CE, UL, TUV, TUV GS, VCCI, cUL, NEMKO, TCO '95
Compliant Standards: UL, CSA, FCC-B, CE, TUV/GS, TCO '95, VCCI-I, EPA Energy Star
Connectivity Technology: Cable
Device Type: Flat panel display / TFT active matrix
Device Type: LCD monitor
Digital Video Standard: Digital Visual Interface (DVI)
Dimensions (WxDxH): 14.8" x 8.5" x 14.1" (height can be adjusted to 18.6")
Dimensions (WxDxH): 37.6 cm x 21.6 cm x 35.8 cm
Dimensions (WxDxH) / Weight: 14.8" x 8.5" x 14.1" / 14.5 lbs
Dot Pitch: 0.26 mm
Dot Pitch: 0.264 mm
Enclosure Color: Black
Image Brightness: 260 cd/m²
Image Contrast Ratio: 400:1
Max Resolution: 1280 x 1024
Max Resolution: 1280 x 1024 pixels (SXGA)
Max Sync Rate (V x H): 77 Hz x 80 kHz
Output Power / Channel: 1 Watt
Port(s) Total ( Free ) / Connector Type: 1 x 24-pin DVI connector, 1 x 15-pin D-sub VGA connector
Power: AC 110/220 V ( 50/60 Hz )
Power Consumption Operational: 40 Watt
Power Consumption Operational ( Standby : 40 Watt (5 Watt)
Software included: Drivers & Utilities
Sound Output Mode: Speakers
Speaker(s): Integrated stereo speakers with 1W/channel
Type: LCD monitor
Type: Speaker(s) - integrated
Voltage Required: AC 110/220 V ( 50/60 Hz )
Voltage Required: AC 110/220 V ± 10% (50/75 Hz)
Power Consumption Stand by / Sleep: 5 Watt
Compatibility: PC and Mac
Compatibility: PC, Mac
Response Time: 16 ms
Display Screen Coating: Anti-glare
Flat Panel Mount Interface: 100 mm
Controls / Adjustments: Mute, volume, contrast, H/V position, sharpness, color balance, input select
Product Description: Planar PX171M - flat panel display - TFT - 17"
Power Device: Power adapter - external
Service & Support: 3 years warranty
Service & Support Details: Limited warranty - 3 years
Manufacturer Warranty: 3 years warranty
Cables Included: 1 x VGA cable ¦ 1 x DVI cable ¦ 1 x audio cable
Interfaces: 1 x VGA - 15 pin HD D-Sub (HD-15) ¦ 1 x DVI-D - 24 pin digital DVI ¦ 1 x audio line-in - mini-phone stereo 3.5 mm
or
VIEWSONIC
VP171b Specs
LCD Type 17" color TFT active matrix SXGA LCD
Display Area 13.3" (horizontal) X 10.6" (vertical); 17.0" diagonal
Optimum Resolution 1280x1024
Brightness 260 nits cd/m2 (typ)
Contrast Ratio 500:1 (typ)
Viewing Angle 140° horizontal, 140° vertical
Response Time 16ms (typ)
Panel Surface Anti-glare
VIDEO INPUT Analog RGB Analog (75 ohms, 0.7/1.0 Vp-p)
Digital DVI-D (TMDS, 100 ohms)
Frequency Fh: 30~82kHz, fv: 50~85Hz
Sync H/V separated (TTL), composite sync-on-green
COMPATIBILITY PC VGA up to 1280x1024 non-interlaced
Mac®* Power Mac? G3/G4 up to 1280x1024
HDTV 480p, 720p
CONNECTOR Analog 15-pin mini D-sub
Digital Digital DVI-D
Power 3-pin plug
POWER Voltage AC 100?240V (universal), 50?60Hz
Consumption 33W (typ)
CONTROLS Basic Power, 1, down, up, 2
OnView® Auto image adjust, contrast, brightness, input select, color adjust (9300K, 6500K, 5400K, 5000K, user color), information (mode, model number, serial number), manual image adjust (H. size, H. position, V. position, fine tune, sharpness, scaling), setup menu (language, resolution notice, OSD position, OSD timeout, OSD background, touch tone), memory recall
OPERATING CONDITIONS Temperature 32?104°F (0?40°C)
Humidity 10?90% (non-condensing)
DIMENSIONS (WxHxD) Physical 392.0mm x 445.0mm x 238.0mm
(w/ stand)
15.4" x 17.5" x 9.4"
(w/ stand)
371.0mm x 309.0mm x 55.3mm
(w/o stand)
14.6" x 12.2" x 2.2"
(w/o stand)
WEIGHT Net 14.3 lbs (6.5 kg) (w/ stand);
9.24 lbs (4.2 kg) (w/o stand)
Gross 18.7 lbs (8.5kg) (w/ stand);
12.6 lbs (5.7 kg) (w/o stand)
REGULATIONS UL, cUL, FCC_B, CB, CE, NOM, TUV/GS, TUV Ergo, (covers ISO13406-2 and MPR II), TCO?99, NEMKO, SEMKO, DEMKO, FIMKO, GOST-R, Hygienic, SASO, PCBC, VCCI, BSMI, CCC, PSB, C-TICK, TUV-S
POWER MANAGEMENT Meets TCO and ENERGY STAR® standards
WARRANTY Three-year limited warranty on parts, labor and backlight.
raining on the picnic: wait til christmas and all 19's will be under 500. imho.
the next big thing will be the 22's.
and then the 30s.
i can't wait!
