Specop 007
Piss on that SVS (Or any other brand) canned stuff.
Build your own. 😎
Build your own. 😎
This man knows what's up.Originally posted by: Specop 007
Build your own. 😎
Haha, wow, 13Hz, I had no idea it went that low! :QOriginally posted by: mAdD INDIAN
Is two subs really worth it though? I think at that point you hit the wall of diminishing returns.
You should aim for the Paradigm Servo-15 sub. The technology in that is amazing, especially if you are an EE who will learn control systems.
They have an accelerometer that measures the acceleration of the cone and feeds that back into a control system. This allows the sub to hit an insanely low 13Hz.
Not sure what hte price for it is...you may need to sell a kidney...which is fair considering that sub could possibly damage one anyway.
Any sub can hit 13Hz. It just matters how loud it is at that frequency and whether or not it'll be damaged. 😉Originally posted by: AgaBoogaBoo
I've got a pair of Paradigm Studio 60's and an HK AVR 335 receiver to drive them, now I need to figure out what I'm going to do for my subwoofer(s).
Right now just to get a reference point I'm using my parents' JBL PB12 that we've had for 5-6 years or so IIRC.
First, I was looking at this: http://www.svsound.com/products-sub-cyl-plpow2.cfm
Then I was also looking at the STF-3: http://www.hsuresearch.com/products/
I'm not too worried about the frequency response of the subwoofer since I'll be watching a lot of movies and most of my music doesn't involve lots of pipe organs or anything hitting pretty low notes and so I'm looking to see if I can save a little money compared to spending $825 on the SVS subwoofer.
My main issue is that I have to power quite a bit of area, this is all in a 14 by 34 foot room with an 8.5 foot ceiling. The single JBL PB12 isn't enough power even with it's turned up pretty high.
I might look around for this slightly used: http://www.svsound.com/products-sub-cyl-plpow3.cfm
Anyone have any advice what I should look for? I have no issue getting 2 subwoofers that are $250-$300 each at all, they do need to push a nice amount of air though. I might end up getting the SVS 25-31 PC+ unless I can find some other kind of better deal.
Build your own. 😎
Build your own. 😎
that's true, customs are awesome 😛
Build your own. 😎
Absolutely. If you have decent knowledge, or get proper help, a DIY sub will smash ANY out of the box sub in the same price point. You'd have to spend exponentially more for an out of the box system to do what a DIY system can do.
Yeah, I'm sure you probably know more than the engineers at companies who do nothing but design speakers for a living.Originally posted by: Specop 007
Build your own. 😎
Build your own. 😎
Build your own. 😎
Build your own. 😎
I'm not talking about just the act of cutting the wood or whatever material you choose to use and putting it together.Originally posted by: Specop 007
Build your own. 😎
What the hell does that have to do with anything?
And for your answer, Yes, I probably DO know at least as much about making something as simple as a damned subwoofer enclosure as those engineers.
Build your own. 😎
This is, of course, given the value of your time = $0. If you make $500 per hour, buying will probably be much cheaper. 😉
Count me in. That's what I want. :thumbsup:Originally posted by: Viper GTSIf money were no object every sub geek would have a parthenon (or several) under their house + custom built chambers for it to play with.
Viper GTS
Viper GTS
And don't get me wrong, I'm all for doing stuff yourself, but for someone who obviously doesn't know that much about it, they're better off buying than building unless they have a friend who's "constructionally inclined".Originally posted by: Specop 007
Viper GTS
Definately. 😎
True, but hobbies are always a labor of love.
Viper GTS
Definately. 😎
No, I would not. Unless it were for the cool factor.Originally posted by: Viper GTS
If money were no object every sub geek would have a parthenon (or several) under their house + custom built chambers for it to play with.Originally posted by: Pacfanweb
Build your own. 😎
Viper GTS
You make it sound so difficult. Sizing the box (shape doesn't matter except that it slightly affects stiffness) is easily done with a box simulating program. With a little knowledge of how the room will affect the response, you can easily put together something that works very well.Originally posted by: Pacfanweb
Build your own. 😎
I was referring to the actual design and how they come up with the shape, size, amp specs, driver specs, ported or not, etc.
Sure, anyone can build a box and buy a driver and amp for it. But unless you simply get lucky, there's no way that's going to be as good as a high-quality production unit.
