richierich1212
- Jul 5, 2002
- 2,741
- 360
- 126
BF3 64 MP is CPU-dependent.
http://www.youtube.com/watch?v=ZIIOQ6WqeEQ
Seems fine to me, 960T + 560ti using FRAPS.
Even with an overclock you'll still be bottlenecked in CPU-dependent games. Don't let the AMD fanboys tell you otherwise.
Of course they'll point to GPU-dependent games and ignore the fact that AMD is pathetic for SCII MP and other CPU-dependent games where the processor does matter.
AMD chips bottleneck HD 6850s in CPU dependent games.
Nice slideshow. A single 560 Ti cannot run BF3 on ultra with decent FPS regardless of CPU.
Care to back up those claims ?
Of course they'll point to GPU-dependent games [..]
Currentgen processors that aren't sissy pansy celeron or Sempron will not bottleneck current gen video cards.. Where do you all come up with this stuff?
45 FPS with dual 5870s is pathetic. Probably your pathetic Phenom II holding you back.Considering that you yourself are the first to bring up benchmakrs from a game favouring your favourite processors a few posts later, you don't have the right to call anyone a fanboy.
The last two PCs I've built for my friends were Sandy Bridge i5's and i7's because those are great processors at that price point. I myself use an unlocked, overclocked 960t for gaming and that's a great processor as well - there's no game I can't run at the highest settings with a good framerate. (I use two XFX 5870's) That includes BF3 MP with 64 player and highest settings. The CPU is used to about 70~80%, both GPUs to 100%. FPS is around 45.
You shouldn't go out of your way to point out how "pathetic" other peoples choices are if they are just as valid but don't correspont with your opinion.
In FPS the frames do matter. Play CS or BF3 with a constant 100 fps then go to 70 fps. Notice how AMD chips hold back a HD 5870, which isn't the fastest card in the world.I dunno, the chart clearly shows that you'll only get something like 70 FPS with an AMD chip instead of 100 FPS with Intel.
Would that make or break the experience? I mean, would 70 FPS be unacceptably slow to where you couldn't enjoy the game?
I wonder if it matters what your display is, whether you have a 60 hz or 120 hz?
As mentioned above the min FPS will be much worse for AMD chips.
No offense, but with your blatant bias, any data with you as the primary source is suspect. Not sure why you post it.
I'm making no claim on the accuracy of this particular graph. What I am saying is that we cannot trust you to perform any objective testing at all. We know any test you perform is designed to make AMD products look better/less bad.
Go somewhere else with your AMD fanboy blog. Your original post was laughed out of these forums.
I'm not the primary source. The trusted review sites like THG and Anand's itself is the source: AMD is bad for gaming.No offense, but with your blatant bias, any data with you as the primary source is suspect. Not sure why you post it.
Conspiracy of all the hardware review sites! That's right!Yes he has an agenda. It's a conspiracy!
AMD fanboys won't ever get over their fascination with clock speed and moar coars.clock speed doesn't seem to do that much in RTS. look at the 4ghz vs 3 ghz i5 are negligibly different.
The big gaps are in going from architecture to architecture. Wide CPUs with great prefetching are at the top and skinny CPUs with poor prefetching are at the bottom.
you would pick SCII benchmark lol ? shameGo somewhere else with your AMD fanboy blog. Your original post was laughed out of these forums.
I'll take Tom's tests over your doctored garbage any day.
Face if fanboys, overclocked AMD is still behind an i3:
AMD fanboy: "But but but there's not an overclocked X4 on that chart (ignores the 980).
In either case, the i3-21xx will meet or exceed overclocked Phenom IIs.
