Have you fellows ever seen a metric tape measure? Every carpenter in the US will be blind a month after the change. Nothing would ever get built again.
You can't do math, so everyone else should change?
"A pint is a pound the world around" - try that with your precious base 10 system.
Let's take volume for example. Yo own a quart measuring device... that's it. With this quart you can roughly figure out a pint by filling half. From this you can roughly figure out a cup by again filling half. Alternately if you fill the quart and dump it in a larger vessel 4 times then you have a gallon.
Try doing the same thing with a Liter container when it is asking for 230 mL.
Sadly the scientific world thinks that everyday man needs to measure stuff precisely. This is not the case, has never been the case, and I seriously doubt it will ever be the case. Metric makes sense when I need precise figures and I am doing math with these figures. It makes it easier for it that time. But when I want rough and dirty measurements, I will take Imperial/American any day.
20 ounces to a pint, 40 to a quart, and 160 to a gallon. Not logical.
I can do math. This is precisely why the arbitrary retardedness of the imperial system needs to go away. There is a better system where everything is base 10 and it has been around since the 1500's. The USA should catch up.
It's not so much that. It's mostly that everyone else uses a measurement system, and we use something else. Stupid really. Just another place for engineers to screw something up in conversion.You can't do math, so everyone else should change?
This...hahahaYou do the same thing...
You fill the litre container up ~ 1/4 of the way.
8 bits to a byte
1024 bytes to a kilobyte [or] 8192 bits to a kilobyte
1024 kilobytes to a megabyte [or] 1,048,576 bytes to a megabyte [or] 8,388,608 bits to a megabyte
I think the Imperial system is doing just fine, relatively speaking
This. There is essentially no argument to be made for Celsius over Fahrenheit. Unless you only measure the temperature of water and care when it freezes and boils.🙄
You should follow us in the UK - decide to change to metric in a flurry of technocratic European-community idealism, then get halfway (or 0.5 of the way) and lose momentum, get stuck, revert to imperial, then decide to try and go for for metric again, then lose interest in the whole business and decide 'what the hell' and let everyone use a mixture of both systems according to personal preference.
So short distances can be in inches or cm, long distances are more often in miles, heights of people are in feet and inches but other things more often in cm, weights of people are in stone but weights of foodstuffs are in kg, temperatures are C or F depending on your age and generation (F means absolutely nothing to me and it infuriates me that so many people still use it). Alcohol and milk are officially in ltrs but everyone still thinks in pints (definitely for booze). And its not unknown to buy things with one dimension given in inches and the other in cm.
(These days, because I can never remember how many yards there are in a mile - its some stupid number that makes no sense - I tend to have to convert from one to the other by remembering 3 feet in a yard, 12" in a foot, 2.54cm in an inch, 100,000cm in a km, and a km is 5/8 of a mile.
C over F makes sense because the normal range of temperatures people experience are a little above and below zero C. I know that 30C is a damn hot day, and that if its below zero its cold and there will be frost. Of course, its really just what you are used to, but temperatures given in F mean nothing at all to me.
Imperial is a perfectly usable system in general though, I wouldn't knock it. People ought to know both I reckon.
The metric system is just as arbitrary. Someone just so happened to have arbitrarily decided to line shit up on the power-of-10 boundaries.
Stop bitching about your own inadequacies and trying to force them on the rest of the world.
Temperature:
0C Freezing
100C Boiling
37C Fever
39C High Fever
32F Freezing
212F Boiling (I had to look this up and I've lived in the USA for over 30 years of my life)
99F Fever
103F High Fever
Which one is logical and which one is batshit crazy?
You're off by about 300 years. But who needs accuracy?
Base 10 allows us to just move the decimal point.
