http://www.pcper.com/reviews/Graphi...eForce-GTX-690-Radeon-HD-7990-HD-7970-CrossFi
Probably the website that is now pushing, divulging, and investigating with the most thorough analysis into frame times has posted it's lastest updated info today. They are using their own unique solution to test frame times (not FCAT).
The results shouldn't surprise you, and it won't surprise AMD any more either - if released today, the HD 7990 would not perform well in our tests. AMD has told me that they are working on an option to meter frames in the way that NVIDIA is doing it, but offering users the options to enable or disable it, but we are months away from that fix. Until then, any dual-GPU Radeon HD 7000-series cards are going to show these problems represented as runts and dropped frames. We have many more pages of results to go over for the HD 7950/7870/7850/etc and those will be published in the coming days - but the story will look very similar as you'll find.
In all honesty, when AMD told me they were planning this card release I recommend they hold off until its driver fix is in place - myself and other reviewers are going to be hitting them hard on these issues until then, and any dual-GPU option with the Radeon name is going struggle to live up to any placed expectations.
Final Thoughts
The second part of our final reveal of the Frame Rating performance methods have shown us some interesting results for the $999 and above card lineups as they stand today. The Radeon HD 7970s in CrossFire, representing the currently available and upcoming HD 7990s don't look great in our testing as we mentioned above, and I would seriously consider your buying decision before picking up this configuration.
