PCI or USB wifi adapter?
Barfo
27,539
212
Title says all, which one will be more convenient to use with a desktop PC running Vista 64 bit?
RebateMonger
11,586
PCI adapters have much better antennas and are less likely to get damaged by impact to what's sticking out of the PC.
JackMDS
29,513
407
Originally posted by: barfo
So PCI > USB?
Yeah that is the logic behind of linking you to a good inexpensive PCI. :thumbsup:
In addition a major problem with many of the current USB wireless is Heat.
Because of their structure in a small Plastic encasement they get very hot and as a result the transmission goes down.
PCI is better ventilated in the case, and most PCMCIA (for laptops) are much better designed and built than the USBs.
heymrdj
3,999
63
Not true lol. I had a linksys PCI card installed in our mobile LAN party server. It got tore off in route to a LAN party 40 miles away. Replaced it with an Edimax USB adapter so I could pack in separately and not do damage like that anymore :).
kevnich2
2,465
8
Well, personally I've gone with the WUSB54G from linksys (V4) and I've had 0 problems with them. Have them installed on 4 XP systems (no vista) and no problems. I like USB over PCI so it's easily removed or moved around if I want. Also, the CD that comes with it has just a driver folder, so I just install that and use windows to manage it, I don't use nor like the linksys wireless client. But it is on the more expensive side $50 approximately
