Hi all,
I just finished doing some hardware upgrades, and my PC seems to not want to actually boot up now.
To explain, my setup had been:
Antec SLK3700BQE case with Antec 350w bundled PSU
Stock 120mm Antec fan (the one bundled with it)
MSI K8T Neo MB
Athlon 64 3200+ with Stock HSF
2x 512MB Kingston HyperX RAM
PNY GeForce 6800GT with stock fan
1 80GB Maxtor IDE HD
1 120GB WD IDE HD
1 Plextor PX-708A DVD burner
1 Sony DVD-ROM/CD-RW combo drive
The upgrades I did were:
Thermalright XP-90 with Panaflo LB1X fan to replace the stock AMD HSF
Arctic Cooling NV Silencer 5 to replace stock cooling on 6800GT
Vantec Stealth 120mm Fan, mounted as an intake fan on the front of the SLK3700BQE
Antec SmartCool 120mm Fan on the back as an exhaust fan, replacing the bundled Antec fan that came with the SLK3700BQE
I used the bundled arctic cooling silicon compound paste with the NV Silencer 5, and I used Antec Formula 5 Silver Thermal Compound with the XP-90
Anyway, after doing these upgrades, and plugging everything back in as it had been before, the computer is no longer starting up properly.
I have the MSI D-Bracker 2 installed, which has diagnostic LED's on it.
The LED's are showing up in this pattern:
Green Red
Red Red
According to the manual, this means "Early Chipset Initiation".
I have checked things out, and I see all the fans spin up when I power on (the two 120mm fans, the fan in the NV Silencer 5 and the Panaflo LB1X on the XP-90).
Can anyone offer me any advice on what the problem might be and how I could fix it? It seems like everything should be OK, but I'm not sure.
Any advice you can offer would be much appreciated.
Thanks,
Zadillo
MSI K8T Neo MB
1 120GB WD IDE HD
Green Red
Red Red
Thanks,
Zadillo
