Originally posted by: TechnoButt
Sorry to hear about your problems, did you ever try another video card (preferably PCI or a semi-modern agp)? When I run into POST problems on a new system, I actually pull the board from the case entirely and set it up loose on a bench (with a static bag underneath if you're paranoid). Then I install a single stick of known good ram (or two if dual channel is required). I use a known good low power video card (in my case, it's a geforce2 mx, but it will soon be a PCI Matrox G450/550 or similar if I can find one). The only other thing I put on the board is the cpu with a stock HSF. Then I clear the CMOS (move the jumper for a few minutes to make sure it's fully discharged.. it will usually reset immediately, but wait a few minutes just to be sure). I plug the power supply into the board and board only. If you can get your power switch lead to reach the board, great.. but I usually power on by quickly shorting across the two posts where the power switch normally connects.
If the system won't post out of the case with known good video/memory/cpu/hsf (I say hsf, because of the chance that too much pressure is causing the cpu to not seat properly, etc), then my next guess would be to verify that the board came with support for the cpu directly from the manufacturer upon shipping. I can't tell you how common it is to get a mobo/cpu from different places only to find out the mobo will need a bios upgrade before accurately detect the cpu. If it doesn't detect correctly, usually the motherboard is supplying too much voltage (newer cpus tend to need less voltage than their older counterparts). If that's the case, then the cpu does not get enough voltage to POST.
So, yuck, good luck? If you could get your hands on the cheapest/most basic CPU that was designed for that board, you could find out if you needed a bios update (and could actually flash the cmos with the older cpu running).
EDIT: BTW, don't get an antec neopower from CompUSA. I just bought one a couple of weeks ago and watched my +12V1 rail droop to +10V several times as my motherboard powered off to protect itself from damage. I'm about to be done with ANTEC for awhile. I'm trying to convince myself to spend the $200+ it will take to get the PC Power&Cooling Turbo-Cool 510-SLI that I really want.
Thanks. Basically everything had been working properly before I put in the new case fans, the XP-90 and the NV Silenver 5.... although as people have pointed out to me, I was probably already pushing the limitd with the PSU I had anyway (the 350w PSU that came with the Antec SLK3700BQE). So part of this will be that I'll wait til I get the new PSU in anyway, since I want to rule that out as an issue (when I've been doing the testing since then I've unplugged the extra drives and the extra case fan to try and help things along, but who knows).
Re: the NeoPower, I didn't buy it from CompUSA, but I ordered it from ZipZoomFly (where it was $109 with free 2nd-day shipping). Is it really that bad a PSU? I've seen almost nothing but glowing reviews and comments on it at the various places I've looked. I don't think it's too late for me to cancel my order, but it seemed like it would be pretty solid to me. I guess I'll see.
