Originally posted by: purbeast0
Originally posted by: Krakn3Dfx
i used to only play FPS on PC.
now i don't play PC games at all and i don't plan on going back to PC gaming ever.
it takes some time to get used to but you can do it no problem. it will never be as precise as a mouse/kb but everyone is on even playing fields. those who cry about controlling FPS on a controller are sad.
the best part is not having to upgrade your computer constantly and being able to sit back and relax on the sofa fragging n00bs on Guardian =D
The best thing about upgrading your PC constantly is that when a game comes out broke, you'll likely get a patch within hours of it being on store shelves if not before it's even out, where as when you have a problem with a game like TF2 on the 360, you have to sit and wait for MS to approve the patch.
I may be sad, but I will play FPS that are available on the PC on the PC first and foremost, and go out of my way to avoid console FPS that would take 17-20 buttons to work efficiently on a PC, but is whittled down to only 8-10 buttons on a console gamepad.
Hotkeys that allow weapon changes on the fly as opposed to being forced to cycle through weapons every time you want to change to something else will always win out in my book. If that's sad, I'll just be sad.
i haven't played a console FPS in years that has a "weapons cycle" button. infact, i can't even remember the last FPS that I played on a console that has one of those buttons where you can carry 143892 different weapons.
Yep - most good console FPSes limit you to two weapons at a time, so its basically just a toggle switch.
Basically, I dont mind dual analog when the game is really created first and foremost as a console game. COD4 plays surprisingly well with dual analog, primarily due to the way it somewhat locks on to an enemy when you pull the L-trigger.
Still, theres no situation in which I wouldnt prefer a mouse, or even a wiimote/nunchuk type controller (as long as it had more buttons).
With any luck, this kind of controller will be standard on the next gen systems:
http://cache.gizmodo.com/asset...8/GyroPod_3Framesb.jpg
Standard analog, motion, IR, split it up, put it together, etc. I'll probably be done with PC gaming for good at that point.
