crt1530
- Apr 15, 2001
- 3,194
- 0
- 0
Originally posted by: paulxcook
Thanks for the thoughts. Bench has always frustrated me, my chest just doesn't grow like the rest of me, but it just makes me want to lift harder, so I'm definitely not giving up.
I haven't done measurements like that in a long time, maybe I should. My wife has some measuring tape she uses for sewing, I could do that. I don't know that I'd want to do it every week, maybe every 2 weeks or every month. What should I measure? I assume waist, upper and lower arms, calves, upper legs, chest, and shoulders?
Usually neck, shoulders, arms, chest, waist, quads, calves. I try to measure the largest part for most everything except the waist since the waist is a bit different.
Also, with chest, what's your biggest problem? Do you touch the barbell lightly to your shirt? Do you have the right grip? Is there anything else that could be a factor with your hindrance of progress?
I usually put my pinkies on the smooth rings on either side of the barbell, try to lower to my shirt and not bounce off my chest. I wonder if maybe I'm letting the weight come too far down my torso. I read recently that it helps to press upwards but slightly toward your head, and if anything I press slightly in the other direction.
Most people are comfortable touching somewhere between the xiphoid process (the bottom of your sternum) and right above their nipples. I would try to stay within that range. When you press the bar, press it straight up.
