Originally posted by: Captante
Only when parked on a slope ... using it all the time just make it more likely you'll have brake problems sooner & also stretchs the cable requiring adjustment.
Nonsense!
Most cars engage the parking brake via a cable & just like the cable on a bicycle-shifter, that cable stretchs over time requiring it to be tightened or replaced to remain effective.
Also the parking brake in many cars & just about all heavy trucks activates the main braking system on one wheel manually clamping the brake-pads onto the rotor/drum ... doing this while brakes are very hot can cause damage over time.
Nonsense!
Originally posted by: eos
Auto trans.
Use foot brake to stop vehicle.
Place transmission in neutral.
Engage parking brake.
Release foot brake.
Profit.
Let car settle against parking brake.
Place transmission in park.
Turn off vehicle.
Open door and exit vehicle.
Nonsense!
your first bit is true, but i've never had to replace a cable. i don't know if you people are driving Kia's around or something, but they have always held up for me, just needing minor adjustment.
your second bit, i feel, is a bit off. yes, the heat and pressure can warp your rotor, but they aren't going to get hotter sitting in the sun than they do when driving. especially if you brake like the idiots around my town. while it could potentially cause undue warpage on one rotor more than the others, this would be a small price to pay if, in the long run, you get more miles out of your tranny. hell, imo, the peace of mind is enough. brakes are meant to be replaced, often. transmissions are not. so if i fuck up o few rotors from time to time and it costs me a few hundred (spread out even), thats a lot better than trashing my transmission and forking out 2-5k(at once) to fix/replace it
Mine doesn't. Separate pads for the parking brake system.
Nonsense!
any time you park, you should use your parking brake (hence the name)
why?
manual tranny only: if a gear slips, it will save the car from moving
all trannys: it prevents unnecessary rock on your gears. if you are on a hill and dont use your parking brake, the weight of the car is resting on your drivetrane instead of your rear brakes. whenever you park on a flat (or seemingly flat) surface, once your car is in park (or 1st/R) you release the brake. when you do so, the car will (unless the surface is perfectly flat and you are kick ass at braking) rock slightly forward or backwards, putting strain on your drivetrane.
now, this is what i've always known, i could be wrong, but it makes sense. anywho, i've been doing it forever and my car has 250k+ on it and has never had anything other than routine maint. 😛
i do this too, except i put it in 3rd or 4th now. one of my cars (at 200k miles) has a stick that is loose towards the 1-2 side from having spent so much time in 1st while parked.Originally posted by: BW86
If I'm driving a manual i'll put it into first and put on the brake
Originally posted by: 2Xtreme21
Eh?
I use mine any time I park, regardless of the grade I'm on. My girlfriend berates me every time I park the car telling me that I don't have to use it... well it's how I learned to drive dammit! Does using the brake when you "don't have to" hurt it?
That is complete bullshit and adjusting the parking brake is very simple, it takes all of about 5 minutes to do.
If time is money, I'd hate to see how much $$$ you've lost with this ritual.Originally posted by: eos
Auto trans.
Release foot brake.
Profit.
Turn off vehicle.
Auto trans.
Release foot brake.
Profit.
Turn off vehicle.
Neutral isn't necessary. Double shift FTL.Originally posted by: BoomerD
Auto trans.
Release foot brake.
Profit.
Turn off vehicle.
Since that procedure IS the proper way to set a parking brake and only takes a couple of seconds to perform, weighing the value of his time against the potential repair costs (and/or towing cost if the weight is on the parking pall and can't be shifted out of park) I'd say it's a debit for time and a credit for repair costs.
Auto trans.
Release foot brake.
Profit.
Turn off vehicle.
