Philippine Mango
Originally posted by: txxxx
If your that worried, route your internet connection via another system, apply QOS to it, then set the default gateway in the DHCP server to your new , traffic shaped gateway. As soon as her PC becomes active, it'll re-route into the traffic shaped gateway, giving p2p very low priority. And she wont know whats gone on.
I was thinking of that but I have netlimiter installed so connections are too much of a problem. But the thing that scares me most is she is too dumb to understand that half the crap she downloads could very well be viruses, and when norton DOES detect a virus she acts like it's an every day thing! I'm worried she will infect our network. I don't have any antivirus software on two on my computers because I'm smart, I've configured IE correctly and I don't download garbage like she does but if she gets a network virus and it screws up my two rocksolid stable systems I'll have a nervous BREAK DOWN!
Then have the firewall ignore everything coming from her system and any other untrusted MAC ID's...and dont do it at IP address level, MAC level just incase the DHCP assigns a new IP to it.
And as for netlimiter, bollocks to that, you dont want to deal with every incoming connection.
An easy path would be to purchase a LinkSys WRT54G/S and use the sveasoft firmware with it, as it has some superb QOS features.
The more teadious (and I think more inefficient path) would be to use a linux based OS and use something like wondershaper or similar. Although I think that might be overkill unless it's going to do something more useful.
Edit: No antivirus , and still using IE makes you very dumb.
IE is perfectly fine if you properly configure it! People think and I guess they should think that things should work out of the box but IT DOESN'T, just like windows XP, you have to configure it. You can run a system with out antivirus and be perfectly fine, antivirus software is for the lazy/ignorant. Last time I got a virus on a 98 machine norton couldn't even detect it! I had to chase it down in the registry and was finally able to remove the dang thing (network virus which originated from a ME machine). I run a check on my system from my laptop (which has norton) every once and a while but still can't find any viruses...
