P180 IDE cabling problem
neutralizer
11,552
I have my HDDs in the lower cage for noise and sound reasons, not to mention that I don't have a fan at hand to place in the upper cage so basically, I can't get the IDE cable to reach. I don't know who designed IDE cables because in every case I've done, the distance between the master (hard drive) and the slave (DVD-ROM drive) is longer than the distance between the slave and the motherboard, yet the cable insists on having a long distance between the slave and motherboard. Anyone know if they sell cables that have the reverse distance? My current cable is 24".
grimlykindo
546
Look for some rounded IDE cables-
They are usually longer and come in more sizes than your standard flat IDE. I got a really long round IDE cable off of TigerDirect.com. Its the same length between the mobo and the master/slave drives. It has come in handy in 2 of my older systems
hope this helps
neutralizer
11,552
hope this helps
Mine is already a 24" rounded IDE cable, it's hard to tell which IDE cables are have what length from the pictures because the descriptions of IDE cables are so bad on every site.
McPudd
153
neutralizer:
On my last 2 systems I've used Promise IDE controller cards for my 2 HDDs and the motherboard IDE connectors for my 2 disc drives.
Each of the 4 drives has a channel to itself and no slaves.
A similar approach in your system may mean everything should "reach".
Happy trailz,
neutralizer
11,552
Originally posted by: McPudd
neutralizer:
Happy trailz,
Damn that's the only solution :(.
I guess it's time to start phasing out my PATA drives for SATA. *sigh*
Can't believe no one has any innovative cabling techniques for the P180 for this.
RDMustang1
4,139
neutralizer:
Happy trailz,
Send the case to me and use a cardboard box :)
Seriously, either get longer cables (max recommended is 18" but 36" work fine for me) or get a PCI card to plug the drives into..
