eyeballkid
- Oct 5, 2004
- 63
- 0
- 0
Originally posted by: Merovingiann
With the heatsink that comes with the AMD FX53, will I have any overheating issues if I raise the multiplier from 12 to 13.5 or 14?
The easist way to overclock a rig with the FX-53 processor would be to raise the multiplier. I would only raise the CPU FSB frequency if I knew my memory could reach higher speeds with the same timings or if I for some reason needed a higher memory bandwidth.
Anyone with a FX-53 and a stable PSU should be able to push it to about 2600 MHz with the stock heatsink (Temperatures can be easily monitored by using the excellent and free MBM5 utility).
Example on K8N Neo2:
"High Performance Mode" - Manual
"Dynamic Overclocking" - Disabled
"Adjust CPU Ratio" - x13
"Adjust CPU VID" - 1.500v
"CPU Voltage" - Over VID 10% (~1.65v)
If the voltage is not enough for your CPU I would invest in a water cooling solution or a heavyset heatsink with a screaming fan before putting 1.7v through that little darling.
Good luck!
