BFG10K
- Aug 14, 2000
- 22,709
- 3,002
- 126
I see six GPU settings that should be on Ultra High but arent. Why not?and again just to hammer it home some guy in another forum with a gtx470 helped me out and ran the long ranch bench at very high settings and 2x AA just like I originally ran it. he had a stock 2.66 i7 and got an average of 101 and a minimum of 55 where all I got was an average of 62 and a minimum of 37 at those settings. he also was even at 1920x1200 where I was at 1920x1080. gee that kind of backs up all those other sites that are getting results like that or better with their overclocked i7 cpus now doesnt it?
So you got an average of 62 FPS? I just ran the same benchmark (with everything maxed) and I got 57.94 FPS average at my settings. Of course I use 2560x1600 with 16xAF and 2xTrMS. That means your CPU is more than enough to saturate a GTX470 at the real-world settings I actually play the game at, so I dont even need an i5 750.
And dont start the bullshit about the CPU affecting the minimums more because my minimum (28.46 FPS) is lower than your 37 FPS. Clearly at my settings the minimum is coming from the GTX470 bottlenecking the system, which again means even your CPU is more than enough to saturate the card.
The game is very playable at my settings, so who do you think has a better gameplay experience? You can upgrade your CPU until youre blue in the face, but that wont give you a 30 display that does 2560x1600, nor will it overcome the obvious bottleneck from the GTX470 at such a resolution.
Thats what I meant when I said the GPU (and display) matters the most to the gameplay experience, by far.
Also, a canned flyby benchmark like Long Ranch isnt really indicative of gameplay performance. Let me put it to you this way: Ive played the game from start to finish on both an E6850 and an i5 750, and I can tell you that in each instance the GPU was the biggest bottleneck by far. Any section with slowdowns ran much better when I dropped the resolution and/or AA level.
So you see, Ive actually made such a real-world comparison with two CPUs and two graphics cards (GTX260+ and GTX285), so I can actually tell you such things about Far Cry 2.
But hey, if you want to base your upgrade decisions on a single canned flyby that isnt indicative of actual gameplay, go for it.
