Opteron 165 Retail $99.99 Shipped @ Newegg!!!
alkemyst
83,769
19
Just bought the 4000+ about 3 - 4 months ago at $79. Runs a lot better than my 3200+ Winchester. Clocked to 2.8GHz.
daveybrat
5,827
1,038
Originally posted by: WhipperSnapper
I wonder about whether I should go dual core, but I really don't want to spend that much for a processor on an unsupported platform. Shouldn't all of the Socket 939 chips be under $150 now?
I currently have an Opteron 148 that I can overclock to at least 2.53 Ghz at 1.425V (while being stable in Stress Prime95 2004). I'm mostly a gamer. Would it make sense for me to buy a 165 or 170 and then eBay the 148? I'd want that 165 or 170 to be able to get up to at least 2.7 Ghz (not sure if my mobo can handle doing that with such a low multiplier).
I went from a 3GHz P4 with hyperthreading to the X2 4600+ in my sig and i have to say that my system is definitely much snappier with the dual core. I love the fact that i can now encode dvd's in the background and still do whatever i want with no slowdown like i got on the P4 system.
Johnbear007
4,570
Originally posted by: sjwaste
Originally posted by: dehemke
This is about where these need to be priced to have any value against the C2D.
I love AMD, but they need to get the new chips out soon. It feels like the K5 days again where they can only compete on low budget builds.
Not really, unless you're one in a small segment of the market that needs bleeding edge, this chip is fine. Even for gaming, I doubt that a 165 is going to CPU constrain you on too many games with an adequate video card at normal-high resolution.
It might be low budget, but unless you have a specific task that actually needs the faster hardware (C2D), it just means you can build yourself a good system on a low budget. In other words, low budget isn't low performance these days.
That is, unless, you just want to tell people you have a cutting edge build. But I think I'm old enough not to care.
I agree....
people talk alot of crap but if you look at the actual gaming benchmarks between an oc'd e4300 and an oc'd 3800 we are only talking an average of 10fps difference max in most game.s This is significant, but hardly the night and day difference that many make it out to be.
GeezerMan
2,146
26
I have read more than once that the larger L2 cache, like the Opty 165 has over the 3800+ X2, means almost nothing in real world use. I would like to see a definitive answer on that though, just out of curiosity.
intogamer
19,219
Originally posted by: RallyMaster
now 103.99?! dammit....
holy cow! that's like two cores for 45ea... the heatpipe is on par with higher end stuff.. 14 for that
nice deal maybe it will dip below 100 :D
GeezerMan
2,146
26
That's pretty good. I think most of the 165, 170, and the 3800+ the egg has are now the LCB9E steppings. Been real good overclockers for some people.
hube235
1,035
Originally posted by: Basilisk
Now $97.
Dangit I knew I shoulda waited. coulda saved 6 bucks :p
While I'm here, here are the steppings of mine:
LCB9E 0704TPMW
I don't plan on using this until I'm "bored" of my 144. The bottom of the stock heatsink has a very nice finish, will edit later w/ pics.
Netopia
4
I've got mine, but haven't opened it yet. I realize that I might have made a mistake in ordering this. I currently have a 4000+ @ 2.88GHz, and hoped to get the Opteron to at least that speed... but was mixed up in my head thinking that just like the FX chips, it had an unlocked multiplier. :( My mobo has not, in the past, liked speeds above 250MHz, so that might limit me on this Opteron to 2,25GHz, which for most basic desktop stuff would actually be SLOWER for me. :(
Ah well... I'll pull it out and try it anyway... who knows, maybe it was the last couple of CPU's that I had that were somehow limiting the FSB.
Joe
BlueWeasel
15,944
475
Originally posted by: hube235
LCB9E 0704TPMW
That's a good stepping, at least based on my results. I got mine last week with the exact same codes and it's running at 2.81Ghz with only 1.35v.
GeezerMan
2,146
26
I think the LCB9E is one of their better steppings. I upgraded a couple of people with the LCB9E 3800+ X2. No problem at 2.6GHZ, and could do more with better cooling. One did 2.8GHz at stock volts, but was too hot while dual orthos testing with a AMD heatpipe HSF
People with boards that have trouble at higher FSB, might want to consider the Opteron 170, at 114.99, with a cpu multiplier of 10.
Dantzig
1,301
I received an Opteron 165 with the Toledo core. After a lot of struggling with the motherboard in my main system which would only hit a 275MHz bus speed, I moved over to my secondary system which has the same motherboard but was able to hit 320MHz bus speed.
With ~1.450Vcore, I was able to reach 2.95GHz core speed. I backed off to 2.7GHz@1.35Vcore 100% stable running Prime95 torture tests on both cores!
Now I have to swap motherboards between my primary and secondary systems . . .
johnnq1
251
i got my lcbqe 170 2 weeks ago. cpu z says toledo, but newegg said denmark...i don't know what to do about it :
i haven't overclocked, but others seem to reach 2.8. this thing runs HOT! 60C orthos with a zalman 7700 alcu fan on high.
BlueWeasel
15,944
475
I'm kinda surprised as well how much hotter this Opteron @ 1.35v (2.8Ghz) runs versus the X2 3800+ @ 1.375v (2.5Ghz) it replaced. I guess the extra cache is the difference?
KenAF2
72
Word on the street is that AMD will slash CPU prices by up to 40% next month. It will be interesting to see what, if any, effect that has on older 939 parts.
I'm still holding out for a $50 Opteron 165.
