IntelUser2000
A dram-less NVMe NAND BGA SSD?
Haha, sounds like a dream. I hope they still ditch the software based solution for a firmware one so its not prone to issues and its compatible with all platforms that use NVMe.
I am starting to wonder if the 815P is a myth.
Still 550 MB/s for the 32GB is super impressive. This and 300 MB/s for the 16GB M15 is the first time I have seen proof that Gen 1 Optane dies can over ~160 MB/s Sequential write per die.
This while also being on the old controller.
I feel the problem for Optane on the consumer side is the large fall in NAND prices over the last year and half. This has greatly extended the price differential between NAND drives and Optane. As such I wonder how much this effects Optane (or 3D xpoint as a whole) product plans for the consumer market.
People are willing to spend crazy $ for top performing products so if Optane was a simple drop in solution it would find a home in the enthusiast market.
High capacity SSDs with low cost NAND paired with high speed Optane would be a cool solution if the actual software lived on the drive itself allowing them to simply appear as a single NVMe SSD to the system.
The hybrid drives offer nothing that I want. I will continue to pair a low cost SSD with an 800p (and later 815p) cache drive and continue to ignore everything Intel wants me to do with their product.
Enterprise and Optane is of course a different matter. The cost to performance (or gain) calculation is also different there.
Main reason I'm getting 16Gb more of ram instead of more optane module is because the price of the 32Gb/58Gb modules isn't cheap enough vs ram.
Persistence makes it a better caching solution(because you don't need to load every reboot), but yes you are right.*
It's still cheaper per GB, but the advantages of greater bit density solutions like Optane(even NAND) only shows in larger capacities. 32GB SSDs are not that cheap, its in the 128/256/512GB capacities where the advantages really show.
So expect Optane to get advantages over RAM in not offering cheaper memory, but by offering greater capacities. Future Optane won't be cheaper, but at the same, or slightly higher cost offer significantly higher capacities.
*Needing to load is the real problem, and where people are looking forward to superfast NV memory like Optane. That's why I'm expecting the DIMM version to be the one that shines.
I have been working with Optane DC Persistent Memory. This is speaking from the Enterprise side, I have no idea what Intel plans for desktop regarding this.
Have to wonder if it would be useful to use Optane PM via PCIe 5 CXL instead of DIMMs.
I finally got my 4X 905P setup up and running (and bootable). I ran into a snag with my Asus Hyper 16X. It turns out that it has crap power delivery and was corrected in a their V2 card.
but for a single user the 1q1t 4k is most important.
