IntelUser2000
(8th-Gen only, apparently, and must be supported by the mobo vendor by a BIOS update?)
Yea, better late than never. I think this might also be related to imminent launch of the Optane H10 drives. Limiting an SSD to Core i3-i9 might be too much!
There is, for 8th gen the supported chipsets are-
Intel® H370 Chipset, Intel® Q370 Chipset, Intel® B360 Chipset, Intel® C246 Chipset (WS), Intel® Z370 Chipset, Intel® Z390 Chipset
So no H310.
Still, its a lot better. The Celeron G4920 is $76 at Newegg.com. Core i3 8100 is double the price at $151. The price difference is worth 16GB Optane + HDD.
Edit:
What's the best/cheapest config for Optane? 32GB Optane Memory + 4TB-6TB HDD? Or 32GB Optane Memory + 1TB Samsung 860 QVO SATA6G 2.5" SSD? Or would getting an Intel 660p 1TB-2TB M.2 NVMe be better, and skip the Optane? Or even use an Optane, with the 660p, as a cache? Would it even make sense to cache NVMe with another NVMe?
If you are going for Intel's official "Optane Memory" configuration with what you outlined above, you could wait for the Optane H10, since that requires support anyway and will likely perform better due to more integration. The integration level goes beyond current Optane Memory and WD^2 and is a step towards full hardware integration like the SSHDs. Pricing might be in the 760p range though. And I'm not 100% sure being available outside of notebooks.
You can't cache NVMe drives(well actually you can with RST, just not with official Optane software which also performs better). I don't know if its them not worth bothering with it(because they said the difference isn't worth it), or its a technical limitation.
