Now you can pin individual applications and folders with the latest Optane Memory driver: https://www.intel.sg/content/www/xa/en/support/articles/000028779/memory-and-storage.html
Needs 32GB or larger Optane to work.
That is awesome. I'm very glad they did that.
P.S. I wonder if pinning the page file shows a difference. (Did the Optane system acceleration software already pin the page file by default?)
The default caching is labeled as 2 things, "System files" and "Top accessed content". These 2 are not delineated further and you cannot "unpin" them.
Pagefile.sys and swapfile.sys cannot be pinned as Optane says that they are in use and need to be closed.
Too bad I forgot to ask the Intel Optane team about this when they were here. (I was also curious about how the RAM caching worked).
I am very curious about Optane as a RAM replacement.
Where from???2 380GB M.2 drives preordered.
Where from???
So are these M2s 22110s? Most boards are only up to 2280..
That length makes these a non-starter for a lot of people.
Even brand new Z390 boards are mostly 2280 max...
Is this geared towards Datacenter?
Looking at ASUS Max line and they all stop at 2280, in fact most ASUS boards stop at 2280.
Would be nice to see a Workstation laptop that could use one (or both) of those of those drives.
EDIT: According to this list Acer Predator 15 and 17/17X can use M.2 22110 NVMe.
Looks like DIMM.2 will likely be the best way to get 2 of these into a desktop.
The other two ports come courtesy of a DIMM.2 riser card that uses a ninth DIMM-like slot on the right of the board to provide two fully fledged PCIe x3 M.2 slots as well as fans for better cooling. We think this is a great idea as it not only looks better than the hideous vertical arrangements we've seen that have the SSD standing up like a skyscraper, but it's also likely they've benefit more from your case or cooler's airflow too. The module makes it much easier to get at the SSDs too and clips in place just like a memory module would.
Ah, DIMM.2.....
I didn't know this existed:
https://www.bit-tech.net/reviews/tech/motherboards/asus-rog-zenith-extreme/1/
DIMM.2 is also VROC compatible so you can link 2 of these drives directly to the CPU and run them in RAID with very little loss to 4K performance.
TH's article with VROC 905P showed 1/2 sequential QD1 throughput and 1/6 random. That's not little.
It's not the physical distance that adds latency, but the algorithm needed to send data in parallel from two drives.
Most of ASUS’s mainstream/high performance ATX boards DO NOT support 22110.All? You mean the Maximus line?
Their ATX boards often support the 22110. The lower end chipsets like the B360 don't, but that's not always the case either. Lot of their H and Z series have 2 slots, with one supporting maximum of 80mm2 length and the second one up to 110mm length.
But I’ll just keep repeating myself, and you’ll just keep repeating yourself without actually researching it.
