Oil Changes
her209
56,336
11
Originally posted by: Insane3D
Originally posted by: her209
Originally posted by: shortspanishguy
Originally posted by: Zenmervolt
do not use FRAM filters.
I second this.
What's wrong with Fram?
Well, to start with...their filters are junk. Cut open an OEM one from the manufacturer, then cut open a similar Fram you get at Wal-Mart...you will see the lack of element material...
What is element material? Is that a fancy word for "filter media"?
mrSHEiK124
11,488
The MS6 comes with a syn blend from the factory. I'm having the dealership do the first change @ 1k miles to get all those break in metals out of there, then @ 3k I'm switching to Mobil 1 5w-30 and doing them myself. The interval in the manual is 5k miles because I meet some of the harsh driving conditions...short drives and I live in an environment where salt is in use. I'll probably just change it every 2500-3500 miles since it's a turbo car, and the peace of mind is cheap IMO. It's like $25 for 6 quarts of Mobil 1, and another $6 for a Mazda cartridge filter...
I keep my cars for 10-15 years, so it's worth it to me...
I'm probably going to be keeping my Altima for a while too, so I'm trying to do the most I can to extend its lifespan. If I want to avoid FRAM filters like the plague, are there any safe brands of filters to choose or safe places to find them?
Insane3D
19,446
It's just another way of describing the filter media...nothing fancy about it. ;)
To others here...not all cars have spin on filters. The Speed has a cartridge filter, and it has a plastic cover underneath the engine compartment, so it's a bit more involved. In mine, I need to open the drain plug on the cartridge housing, then take off the cap for the housing, and change the element and the o-rings. I actually like this way better because you can see your filter media and anything it's caught. I also like the cover underneath because it keeps all that road spray and crap out of the engine bay...but it can disguise leaks.
Also, I'm not a fan of ramps...but thats just me.
giantpinkbunnyhead
3,251
Yes. use the OEM Nissan filters.
Pepsi90919
Originally posted by: Icepick
I always use the basic least expensive oil.
Take the oil to a repair shop that will recycle. Places like Valvoline and QuickLube will accept used oil for recycling. NEVER pour it down the drain.
probably the best post in this 'yet another' oil thread. i used to be a BITOG nut for a couple years but then realized how cost-effective dyno and PAO synthetics and high-end filters weren't overall.
Insane3D
19,446
Purolator and Wix make good filters...and Mobil 1 makes their own filters, but they are a bit pricey. Purolators high end filter, the PureOne is supposed to be excellent as well. Are the stock Nissan ones expensive? Those should be good as well...and I think Napa's Gold line filters are made by Wix and good as well.
thehstrybean
5,727
I use mobil 1 syn. in my hybrid. I drive mainly highway and change around 8k with an extended life filter.
Changing oil is very easy you just need to get access to the underside of the car.
Hmm, how's 2 jacks sound? I can just buy Mobil 1 locally at Wally World or Target, right? Where do I go with the old oil; can't be safe for the drain...
Jack stands, yes. Regular jacks (scissor jacks, butterfly jacks, are VERY unstable. Use stands). I use Quaker State 4x4 Synthetic in my Jeep. Get a new filter too. Fram is cheap but not the best.
Insane3D
19,446
You can get 5 quart jugs of Mobil 1 pretty cheap at wally world. I just got a jug of 5w-30 for $22. I would get a decent floor jack and a set of jack stands. Also make sure to find out the jacking points of your vehicle...it should be in the manual.
her209
56,336
11
I second this.
http://minimopar.knizefamily.net/oilfilterstudy.html
There are other studies supporting the same evidence.
Hmmm that's informative. But I think if he had cut them open AFTER they have been in use for their rated milage usage, it would give us an even BETTER picture.
Allanv
905
my BMW with synthetic recomends ever 15000 miles although the computer will adjust depending on the driving i do mostly motorway / freeway driving
OS
15,581
i've used synthetic since my car was broken in to 90K and when you look inside my oil cap, the valvetrain looks new, shiny, silver.
Look inside other cars using only dino and there's some varnish, if the car was not regularly maintained, it is quite brown inside even with about half the mileage.
word on the street now is mobil 1 has gone "fake" synthetic like syntec (no GC), etc. all the other retail brands.
Insane3D
19,446
On my Mobil 1 bottle I just bought, it says explicitly "Fully Synthetic Motor Oil". If it was not true synthetic, wouldn't they violate truth in advertising laws? Why would they do this after many years of being highly regarded among synthetics?
Do you have any more info on this other than the "word on the street"?
Edit:
I'm reading a bit about it now on the BITOG forums, and it's really hard to tell exactly what's going on. The biggest thing people are howling about is the fact they changed to Group III, but it seems there are so many people on that forum obsessed with oil, that they are very set in their ways. Some seem to bash M1 because of it's new classification, some seem to like the new Penzoil Platinum, some will only use Redline or Amsoil. A lot of them though are looking for high oil change intervals of 10k+, where I imagine these differences are more important. Personally, I'm going to be changing at such a low interval (3k-ish) that I'm not particularly worried about using Mobil1.
SoulAssassin
6,135
Originally posted by: giantpinkbunnyhead
As far as how to change oil, it's pretty easy...
1) Place front of car on ramps or jack stands (never never crawl under the car if supported only by a jack! too risky) Ramps are safest.
2) Undo drain plug on bottom of oil pan. Oil can be hot and make sure you have a big catch pan ready. Most drain plugs use 17mm or 19mm wrench size, but I dunno about Altimas.
3) Let oil drain out; plug drain hole.
4) Remove old filter, screw on new filter. I prefer OEM filters, not that cardboard Fram crap. They're usually only like $2 more anyway.
5) Pour in one quart of oil; check for leaks.
6) If no leaks, pour in rest of oil up to mfr's recommended quantity and put oil cap back on.
7) Verify oil level with dipstick; check once more for leaks (around drain plug, around filter, etc.)
8) Clean up any spilled oil and take used oil to recycling center / waste center / Kragen / whatever.
9) Take money saved by not having jiffy lube jockeys do that work and buy beer.
I think it's more like:
1. Go to auto parts and write a check for $50 dollars for oil, filter, kitty litter, hand cleaner and scented tree.
2. Discover that the used oil container is full. Instead of taking it back to O'Reilly to recycle, dump in hole in back yard.
3. Open a beer and drink it.
4. Jack car up. Spend 30 minutes looking for jack stands.
5. Find jack stands under kid's pedal car.
6. In frustration, open another beer and drink it.
7. Place drain pan under engine.
8. Look for 9/16 box end wrench.
9. Give up and use crescent wrench.
10. Unscrew drain plug.
11. Drop drain plug in pan of hot oil; get hot oil on you in process.
12. Clean up.
13. Have another beer while oil is draining.
14. Look for oil filter wrench.
15. Give up; poke oil filter with screwdriver and twist it off.
16. Beer.
17. Buddy shows up; finish case with him. Finish oil change tomorrow.
18. Next day, drag pan full of old oil out from underneath car.
19. Throw kitty litter on oil spilled during step 18.
20. Beer. No, drank it all yesterday.
21. Walk to 7-11; buy beer.
22. Install new oil filter making sure to apply thin coat of clean oil to gasket first.
23. Dump first quart of fresh oil into engine.
24. Remember drain plug from step 11.
25. Hurry to find drain plug in drain pan.
26. Hurry to replace drain plug before the whole quart of fresh oil drains onto floor.
27. Slip with wrench and bang knuckles on frame.
28. Bang head on floor board in reaction.
29. Begin cussing fit.
30. Throw wrench.
31. Cuss and complain.
32. Clean up; apply Band-Aid to knuckle.
33. Beer.
34. Beer.
35. Dump in additional 4 quarts of oil.
36. Beer.
37. Lower car from jack stands
38. Accidentally crush one of the jack stands
39. Move car back to apply more kitty litter to fresh oil spilled during step 23.
40. Test drive car
41. Get pulled over; arrested for driving under the influence.
42. Car gets impounded.
43. Make bail; get car from impound yard.
Money Spent:
$50 parts
$12 beer
$75 replacement set of jack stands; hey the colors have to match!
$1000 Bail
$200 Impound and towing fee
Total: $1337
her209
56,336
11
Originally posted by: Mackie2k
Take it to dealer....changing your own oil is WAY overrated.
Oil cost $5 a quart. It takes 30 minutes at the most.
OS
15,581
Edit:
you must not be familiar with the syntec lawsuit from maybe 10 years ago.
Once upon a time, M1 was group 4 oil, Castrol Syntec was group 3. The difference is group 3 is broken down from larger molecules (from crude oil), group 4 is made from smaller molecules.
Mobil sued Castrol over advertisting this group 3 oil as full synthetic, and Mobil lost. Until M1 gave in, all the other retail brand "synthetics" were also group 3.
Anyways, couple months ago some veep of hatco shot some M1 through a gas chromatograph, and said that M1 is mostly group 3 now. This correlates with how some people have noticed the spec list on M1 now often has worse numbers than a couple years ago.
So the mighty M1 is probably now the same type of oil that they once sued Castrol over not being real synthetic. It is more a complaint about principle than practical benefit. Group 3 can work fine, but basically there is nothing special about M1 over any other retail synthetic now.
Insane3D
19,446
Yeah, I was not familiar with that.
It still seems like they aren't made from conventional oil though...this was a response someone got from Mobil..
Thank you for your inquiry,
To meet the demanding requirements of today's
specifications (and our customers' expectations) Mobil 1 uses
high-performance synthetic fluids, including polyalphaolefins
(PAO),
along
with a proprietary system of additives. In fact, each Mobil 1
viscosity
grade uses a specific combination of synthetic fluids and
selected
additives in order to tailor the viscosity grade to its unique
requirement.
Mobil1 motor oils are still 100% synthetic motor oils and do not
use
conventional basestocks in the formulation.
Thank you for choosing ExxonMobil products.
If you need further assistance, please contact ExxonMobil at
1-800-ASK-MOBIL
-Matt Jacob
I'm heading up to Advance to get a couple cases of the Penzoil Platinum since it's on sale...
OS
15,581
(PAO), along with a proprietary system of additives. In fact, each Mobil 1
viscosity grade uses a specific combination of synthetic fluids and
selected additives in order to tailor the viscosity grade to its unique
requirement.
use conventional basestocks in the formulation.
1-800-ASK-MOBIL
-Matt Jacob
It's not really conventional oil either of course, those are considered group I/II. Group III has additional processing that gives it qualities approaching a group IV. It's more a matter of pedigree than quantifiable benefit.
If you carefully consider the Mobil response, it might be construed as slippery worded. Note it does not say all PAO, only that it includes PAO. The amount of PAO used is not dislosed. And we've already established that any motor oil co can legally claim a group 3 is a "full synthetic".
Insane3D
19,446
Gotcha...
Well, since my interval will be so short, I'm thinking it's a safe bet that any decent synthetic will be fine. I just got back from Advance with two cases (12 bottles) of the Penzoil Platinum for ~$34...not bad..not bad at all. When I told the guy that was just enough for two oil changes he was like..what kind of car do you have.
:D
RU482
12,689
SMUGNESS alert!!!
j/k
