NVIDIA has since retooled Pascal for the professional workstation market as well, with products that make even the GeForce GTX 1080 and TITAN X look quaint in comparison. We're speaking of the beastly Quadro P6000 and Quadro P5000 -- Pascal powered behemoths, packing up to 24GB of GDDR5X memory and GPUs that are more capable than their consumer-targeted counterparts. Though it is built around the same GP102 GPU, the Quadro P6000 is particularly interesting, because it is outfitted with a fully-functional Pascal GPU with all of its SMs enabled, which results in 3,840 active cores, versus 3,584 on the TITAN X. The P5000 has the same GP104 GPU as the GTX 1080, but packs in twice the amount of memory – 8GB vs 16GB.
The Quadro P6000 looks very similar to the previous-gen Quadro M6000, which was based on Maxwell. The cards feature the same black and bright-green coolers, dark PCB, and similar connector placement all around. The P6000 is a much more capable beast, though. As previously mentioned, the card is packing 3,840 CUDA cores, with 24GB of 9Gbps GDDR5X memory, linked to the GPU via a 384-bit interface. The GPU has a base clock of 1,417MHz and boost clock of 1,530MHz. At those frequencies, compute performance tops out at about 12 TLFOPs, with 432GB/s of peak memory bandwidth. The Quadro P6000 is also rated for max power consumption of 250W, which is right in-line with the previous-gen M6000, and requires a single 8-pin supplemental power feed.
http://hothardware.com/reviews/nvid...0-workstation-gpu-reviews#eIDLiJbfUMjJcSDr.99
