News NVIDIA and Intel to Develop AI Infrastructure and Personal Computing Products
Joe NYC
4,195
5,764
Another thing I picked up from the conference call: Intel / NVidia client PC is to use NVLink to connect CPU and GPU.
From what we have seen from AMD Strix Halo and Medusa Helo leaks, these processors will have memory controllers on the iGPU chiplet. Which, presumably, NVidia / Intel will also implement.
So, this will then mean that for Intel CPU chiplet to get access to memory, it has to go over NVLink to the NVidia GPU. Intel will have to go over foreign IP just to get a memory access for its CPU.
This to me, this looks like a surrender on part of Intel.
Joe NYC
4,195
5,764
Every + Intel added after 10nm+++ over the last decade was foreshadowing unconditional surrender
A lot of people lived under the illusion that Intel's problems are centered around fab missteps.
But with this deal, Intel is basically licensing 2 sets of IP from NVidia. Which means, can no longer create its own IP.
adroc_thurston
8,471
11,197
you're making a dumb assumption. don't.
GB10 itself has NV tile for basically just graphics. And it'll be the same here, too.
This is nonsense.
Joe NYC
4,195
5,764
It is an assumption, but why do you think it is dumb?
@Kepler_L2 posted that he thinks Medusa level GPU chiplets will be the ones with the memory controllers, not CPU chiplets. It makes sense when it gets to > 2 memory channels.
Why would NVidia do it differently, and not have the memory controllers on the GPU chiplet?
adroc_thurston
8,471
11,197
You're applying AMD things to companies not AMD?
I know what gfx13 is jfc.
more flexibility and you get to offload validation costs to someone else.
see gb10/n1x.
adroc_thurston
8,471
11,197
Why would Intel be selling a CPU with NVLink with nothing attached to it? Rather then on of its other CPUs without the NVLink?
you do understand that the d2d PHY will probably be flexIO with NVL-C2C being one of the protocols supported?
Joe NYC
4,195
5,764
I suspected it may just be the a protocol.
But if memory controllers are indeed on the GPU die, that will still mean Intel CPU will have to access its memory via someone else's protocol.
It is by no means given that the NVidia's iGPU chiplet for Intel will follow GB10. AMD will be going to 2nd generation of Halo product with memory controllers on the same die as iGPU. Which may suggest that it is a more optimal solution.
adroc_thurston
8,471
11,197
and?
RISC-V shithouse talks almost universally in AMBA CHI and this hasn't been a problem even once.
AMD always does things their own way, stop applying their crackpipe worship to everyone else.
Joe NYC
4,195
5,764
and?
It's just ironic how far the mighty have fallen if Intel's CPU cores have to use someone else's protocol to access memory.
There have been multiple approaches by AMD to chiplets and they never had one where the memory controllers / PHY were on the same die as CPU, and multiple on where memory is on the same die as memory controller.
But, on Intel side, it appears that Intel is going back to having the memory controller on the same die as CPU (with Panther Lake).
BTW, this gives NVidia opportunity to copy the entire AMD GPU roadmap, and have this iGPU chiplet to be the bases of low end GPUs using LPDDR5
adroc_thurston
8,471
11,197
No?
again please stop applying permament AMD 24/7 cracksmoke to anyone else.
NVL has discrete SOC tiles again.
They don't have to.
Doug S
3,813
6,749
So Apple could not create its own IP when it licensed GPUs from Imagination? Qualcomm could not create its own IP when it licensed CPU cores from ARM?
Joe NYC
4,195
5,764
Intel is now licensing IP for what is Intel's core business, replacing own IP with licensed IP.
Not the case in your examples. In fact, Qualcomm is going the opposite direction and developing its own Arm cores.
jpiniero
17,154
7,535
Intel is not licensing anything other than NVLink.
I was under the impression that nVidia will be the one selling the products, if any end up coming out.
adroc_thurston
8,471
11,197
Genuinely wonder what happened there. Apple managed to piecemeal rebuild imgtec IP bit by bit starting with A8.
omaigotto Xscale existed and after that Intel used imgtec GPU IP for Atom. And modems. They used external modems before buying out Infineon's radio business.
Your poasts are straight up embarrassing.
yes for DC, no for client.
poke01
4,809
6,140
WoA will become irrelevant as soon as Nova Lake comes out. This Nvidia deal with Intel, killed it even more
