NV5 killed my card? FIXED !!
hey, glad your card is fixed. you could have said something about being able to see your BIOS screen earlier on, that was a huge hint that it wasnt your video card 😉
good work guys, you saved him a lot of hassle/money!
Nick
Originally posted by: Plumcuda1
Originally posted by: hi5
Any beeps from your motherboards.
I doubt u have damaged something or it must be static charge.
The same thing happened recently with my motherboard.
As for RMA.. Piece of cake. Just make sure the resellers arent here to read ur posts.
Chill!!!
No beeps ... as soon as it goes into windows I have nothing. Only thing I could guess, after a few have said it, is static. I never felt any ... ..
^^^^^ I did 🙂
Originally posted by: r55741
odds are very good you will get a new one, unless theres some seal you broke when the heatsink came off....
exactly there seems to be no seal between the heatsink and the card the only way of knowing is if you mount it the wrong way.
i sent mine to bfg i got nothing to loose and everithing to gain.
There is no seal. The biggest problem about getting it RMA'd is having a proper receipt. They will not accept a receipt fro paypal or ebay. So I need to try and get ahold of the seller on ebay and see if he is a PNY dealer... if not I would need something from the dealer he bought it from .....[/quote]
yep i'm gettin a new card from bfg they didn't ask for recipt or anyrthing they asked me what the probllem was i sen't the card to them and they sent me a new one(o and i cleaned the card reaal good so it seemed brand new).
well, ok, he said that it worked when he sent it, but it was new in box. It apparently was never tested then. I guess u just had me going if he knew it worked...
