NV5 killed my card? FIXED !!
jjzelinski
3,750
That means it may be a software issue, a WINDOWS side software issue. If you got into safe mode then your cards 2D is working fine (which was also indicated by the very fact that you could see your system POST.) If that is the case you need to expound more on the circumstances that lead to your delema, such as new drivers, OS changes, any system OC'ing (BIG one.) Spill the beans!
Plumcuda1
911
I did nothing but add 2 new case fans and install that NV5 ... didnt even end up putting that on. So no changes!
uOpt
1,628
So when it comes up in Windoze, what is thre reported temperature?
Plumcuda1
911
What temp? cpu? with this old GF2 I am on? My cpu is idling at 34c
shimsham
10,765
Originally posted by: Plumcuda1
When I press F8 in boot up it takes me too the boot order menu... not safe mode.
some boards use a diff. key. check your mobo manual or google search for it.
fstime
4,382
Right before windows starts loading you press f8, then you chose Safe mode from the menu, regular safe mode.
Duvie
16,215
What is your current power supply?? What was the old card your removed for this GT??? Did you test this thing before trying to install the NV5??? If not that was really stupid...It may have had issues before and now you will never be able to claim them....
Plumcuda1
911
PS is an Antec true550
Old card was a FX5950 Ultra
This card was working before I tried to install the NV5
Duvie
16,215
That is all good....
Did you remember to plug all the 4 pin molexes in the right place (back in)??? The GT AGP has 2 right??? or is that just the ultra??? If it does have 2 make sure on not a Y and use separate lines from the PSU...
fstime
4,382
You got in safe mode with your 6800? If so, your card is FINE! It is a windows problem I would assume, I knew somthing was wrong when it froze during load up, I suggest you back up your data and format or find whats wrong with your windows in safe mode. In safe mode Uninstall nvidia's drivers, reboot with your 6800, reinstall drivers, see if that works, if not I think you would have to format.
Plumcuda1
911
FIXED!!!!!! SOB .... I went and uninstalled rivatuner... thought maybe that was doing it as that was the last thing i DL'd. Rebooted ... nope... SO back to safe mode into device manager and uninstalled my card there. rebooted and It works!
THANKS GUYS!!! I was going to order a new card this afternoon!
McArra
3,295
Congrats, it must be quite frightening to brake a 6800GT, especially for your bank account.
My little 6800GT you won't break down, will you? I hope not...
