I figured that I had everything set with my experience with this board, hardware and software that I could do a nice clean installation and partition my drives without a hitch....BUT NOOOO, we can put a man on the moon but can't have a pc that works without a hitch...grrrrrrrrrrrrrrrr
PRIOR to my re-installation, everything was working fine until something went amiss so I decided to do a clean install.
Original Problem:
Mad Onion 2001 plays for perfectly and then:
BLUE SCREEN giving me that infinite loop error, nV_4disp.dll error
So, I removed the 2.3.1.2 certified XP drivers and put in the ones that original worked; the 22.80. No luck...same problem.
No overclocking
CPU temps are fine as always
Experimented with more conservative memory settings to no avail. Did a memory test on my Mushkin RAM and it passed.
Question:
I know it's a common problem with many systems, but I am curious on what solutions you have come up with?
PS: Fast Writed disabled, tried various aperture sizes, disabled com ports that are not in use and I have no conflicts:
IRQ 0 System timer OK
IRQ 1 Standard 101/102-Key or Microsoft Natural PS/2 Keyboard OK
IRQ 5 NVIDIA GeForce3 OK
IRQ 7 Creative AudioPCI (ES1371,ES1373) (WDM) OK
IRQ 8 System CMOS/real time clock OK
IRQ 9 Microsoft ACPI-Compliant System OK
IRQ 10 3Com EtherLink 10/100 PCI For Complete PC Management NIC (3C905C-TX) OK
IRQ 11 VIA Rev 5 or later USB Universal Host Controller OK
IRQ 11 Windows XP Promise FastTrak100 (tm) Controller (PDC20265) OK
IRQ 13 Numeric data processor OK
IRQ 14 Primary IDE Channel OK
IRQ 15 Secondary IDE Channel OK
Problem solved!
I was experimenting with different memory values in bios without any success but finally removed one of the 512MB DDR 2100 from the board. It worked perfectly!
Mad Onion 2001 played in a continous loop for well over 2hours without a hitch, scoring 7989 without overclocking my CPU or my video card.
I proceeded to install a few games, Half Life and DeuceX without any problems!
I decided to switch DIMMS to see it the second one was defective, but it worked perfectly as well.
I decided to install the second DIMM in slot #3..AND IT WORKED TO MY SURPRISE:Q
Question
WHY?
Could it be that by playing Mad Onion on the 1 DIMM successfully for over 2hours, that WindowsXP may have adjusted itself to accomondate the task?
Could it be that the 1st and 2nd slot conflict? Which doesn't make sense because prior to re-installing WindowsXP on the exact same hardware conditions, I had both DIMMS in slot 1 and 2 without any problems.
This is insane!!! but it is resolved.
Original Problem:
No overclocking
Question:
Problem solved!
Question
WHY?
