Megatomic
- Nov 9, 2000
- 20,127
- 6
- 81
Maybe my wait won't be in vain this time.Originally posted by: BentValve
Yeah baby!![]()
Yeah baby!![]()
Originally posted by: Anand Lal Shimpi
Something you should take note of, look at the configuration in which the test was run (16x12, 4X AA, 8X AF); that should tell you a bit about NV35 already.
You won't hear anything from NVIDIA until the chip is ready to go, they're keen on not making the same mistakes over again. I'm not too surprised this test info got leaked, I saw it a couple of months agoalthough I would expect tighter control from NVIDIA surrounding NV35
Take care,
Anand
Might be the case, but NV35 isn't relying on Low-K; NV40 might be a different story. I guess Orton was a bit bold in his claims that the 9800pro would retain the performance crown through the end of the calender year. Certainly doesn't look too likely that we'll see a CY'03 debut for R400 (or NV40 for that matter).Originally posted by: GTaudiophile
I thought both ATi and nVidia were having issues with TSMC's Low-K process with that being the stumbling block to both NV35 and R400.
Chiz
Originally posted by: PrinceXizor
Here's an idea for all you modder's/tinkerer's out there....someone willling to downclock their 9700 Pro and/or 9800 Pro to 250 MHZ and see what IT gets for fps in quake3 at these settings...
Also notice that no mention of what the memory clocks was set at....it only mentions that the chip clocks were equalized.
An interesting tidbit to be sure, but since NV35 is still many months away...may I point out that comparing 9800 Pro to NV35 is comparing something that exists (i.e. production) vs. something that does not exist.
But then again....its fun to speculate!
P-X
A recent interview with Orton confirmed that ATi is sticking to a 6-month cycle and that we will see something else from them this year.
David Orton: I hadn?t seen these reports (laughs). I think one of the challenges - you mentioned it right in the first question ? is that the R&D-costs are increasing. So there?s the question of ?How often do you innovate the base platform?? and I think that there?s the possibility that you might want to stretch the major steps in innovation to 18 or 24 months. But the idea of innovating within that base has to happen at a rapid pace. The spring and fall cycles don?t change on the calendar so our mission is still to deliver to the spring and to the fall. We?ll do that through incremental innovation off the base.
I think the base is being driven to some extend by how quickly the APIs evolve: If they start to move forward at a more rapid pace, you?re going to have to change your base. If they move forward a little more slowly then you will incrementally innovate underneath that base. So we?re committed to deliver at a rapid pace.
Originally posted by: Shamrock
look at NVnews again at another article post they made.
Topic called "ATI Get Ready!"
they had a conference call with NVidia's president and he had a demo of 4 dawn demos running (that is 4 dawns on one demo)
Originally posted by: jeffrey
IMO ATI did not go far enough with clock speeds on the 9800 Pro.
I believe its supposed to OC pretty well.
