NV35 Benchmarks from Cebit. 131% Faster than NV30..and its downclocked! *Post from Anand Inside*
JayPatel
4,488
Got this from NVNEWS....can you say :Q :Q :Q :Q
Our reader Lax was kind enough to translate and send in part of the article from chip.de's website. They mention some interesting stuff about the upcoming NV35 GPU.
NV35:
256 Bit Memory Bus
500MHz DDR I (Effective 1000MHz)
500MHz GPU
Low noise cooling solution (Different from NV30)
Here is the translation:
While running a quick benchmark in Quake3, 1600x1200, 4XAA and 8xAF it got 111 FPS, compared to a GeForce FX Ti5800 Ultra that got 48 FPS. However both chips were clocked at 250MHz because it was still a prototype, and they wanted to make an exact comparision to the NV30. So basically both were set to 250 in order to make a fair benchmark.
ElFenix
102,402
8,574
great, but can you really trust nvidia's settings to be accurate?
chizow
9,537
Don't know how they would manage to pull a Quack, considering the people who allegedly witnessed this were hardware reviewers that do this kind of benchmarking all the time. :)
Chiz
dangereuxjeux
142
We have to be wary of early reports like these... but let's just say that if they can live up to these numbers, they will have a great product on their hands... be curious to see how they reached 500Mhz clock for both memory and chip if those numbers turn out to be accurate.
chizow
9,537
They downclocked the 5800 Ultra; probably b/c the NV35 is early silicon and is having problems running stably at higher clocks.
Edit: Btw, this is a repost, but I'm too lazy to dig :)
GTaudiophile
29,767
33
Guess nVidia hasn't learned that it was exactly this kind of hype that ended up screwing them with NV30
BoberFett
9
So basically, if those numbers are to be believed, the chip due out in a few months will be 4 times as fast as anything currently on the market?
If they pull it off, it'll be nothing short of astounding. But those kind of leaps are rarely made, so I'll believe it when I see it.
Also, where are they going to get 500 Mhz DDR? I didn't realize there was a pile of PC8000 chips sitting around waiting for Nvidia to use.
erikiksaz
5,486
4 times the speed of anything out there? Wasn't it just 4 times the speed of the old 5.8 ultra?
BoberFett
9
Twice as fast as the 5800 Ultra, which is roughly as fast as the top ATI chip.
dangereuxjeux
142
twice as fast when underclocked, I thought this said... has anybody else heard anything about this display at cebit elsewhere... (hoping like hell that anand somehow manages to get a copy of this card a whole lot sooner than we might think so we can confirm these numbers, c'mon anand.)
erikiksaz
5,486
With that said, i don't understand this :confused:
Wasn't it known that one major weakness of the nv3x was the 128bit memory bus?
magomago
10,973
14
Whoa...I don't beleive it though b/c that is crazy. UNDERCLOCKED and it'll be TWICE as fast as the 9700pro!!!
I know the 9800pro is pretty much on par with the 9700pro until you crank up all the eye candy (whic is what everyone does) and then it defeats it pretty nicely...
But TWICE
WEll...maybe the price of the Geforce4s will actually fall :\
Leon
2,215
4
It's twice as fast based on same clock speed, not 4x as fast. NV30 was downclocked to make it a fair comparison. Assuming NV35 will be clocked the same as NV30, it will be 2x faster than NV30 (based on these results), and 30-80% faster than R350, depending on situation.
Anand Lal Shimpi
Boss Emeritus
Staff member
Something you should take note of, look at the configuration in which the test was run (16x12, 4X AA, 8X AF); that should tell you a bit about NV35 already.
You won't hear anything from NVIDIA until the chip is ready to go, they're keen on not making the same mistakes over again. I'm not too surprised this test info got leaked, I saw it a couple of months ago :) although I would expect tighter control from NVIDIA surrounding NV35
Take care,
Anand
chizow
9,537
Take care,
Anand
:Q So I guess this brings validity to the news bit. :D
I want one now!!! ARgggghhh. Great point about the resolution. Looks like the 256-bit mem interface is confirmed, as that seemed to be the only thing holding the NV30 back in AA and AF settings at high resolutions. There should be a decent improvement w/out AA and AF though if they clock it the same as the 5800 Ultra. Time for that core to stretch its legs with its impressive fillrate. :Q I guess it would be too much to ask for an 8x2 pixel pipe though. Don't think an extra 5 million transistors is gonna get that done. Maybe tweaked memory controllers?
Bober, that's a good point about the memory speeds. Is there even 2ns DDR-I out there? I think some of the newer NV31, NV34, RV350 parts are shipping with fast RAM, like 2.5ns @ 400MHz. 500MHz though...hmm. I'm hoping a later revision cools it down as well....FlowFX is not something I want to hear when gaming.
Anand, quick question though. You seemed a lot more restrained in one of the flurry of articles you put out on the NV31/NV34/RV350 previews (I forgot which one) when alluding to the NV35. I know you mentioned you saw working samples, but your comments seemed to be mixed. Was this by design, or out of deference to nVidia? I did pick up the hint you dropped about it competing with the 9800pro and not the R400 as many believed.
Chiz
First
10,518
271
Chiz
NVIDIA will send their NV35 Assassins Team to North Carolina if we say much more. ;) :D
Alekz
13
Was the memory also underclocked? If so, it is possible that the NV35 will have a slightly smaller advantage at final clockspeeds (i.e. the core could have 2.3X the fillrate of NV30, but the real-world memory bandwidth could be only 1.9X or something). DDR-I...hm, seems odd.
GTaudiophile
29,767
33
According to Anand's review of the Radeon 9800 PRO, it scores 128.5 FPS in QIII with 4X AA/8X Perf Ansio at 1600x1200x32.
I don't see the big news here. By the time NV35 is released, the Radeon 9800 PRO will cost much less and offer say 20-40 fewer FPS in said benchmark if that? And if nVidia releases NV35 this summer or fall, they'll be getting close to R400's release date.
jdogg707
6,098
But they said it was clocked down by half the original specs for a fair comparison, so I would think that by increasing the speed by another 250MHZ for the final product we will see more than a 20-40 FPS differece.
Ferocious
4,584
Looks like NV35 will be to the 9800PRO what the 9800PRO is to the 5800 Ultra.
Nviida shouild be retaking the crown shortly.
GTaudiophile
29,767
33
I don't think another 250mhz is going to produce 222 FPS in that benchmark, sorry.
Yes, I expect nVidia to take the crown with NV35, but I also expect ATi to respond swiftly with R400.
