Nuclear Car
QuantumPion
6,010
Thromium is used because it needs much lower temperatures to remain critical. Also, is less radioactive then uranium or plutonium. Still several hundreds of degrees needs to be maintained. And thromium reaction is more difficult to start.
Pretty much every single statement you've made in this thread is 100% wrong.
Thorium is is not fuel, it is breeding material. It is used because it is more common and cheaper than uranium. It is just as radioactive as U or Pu and and reactors using thorium for breeder material produce just as much radioactive byproducts. Again, temperature has nothing to do with criticality. And a reactor using thorium for breeder material is no more difficult to start than any other reactor.
QuantumPion
6,010
A Thorium reactor needs a neutron source to kick it off and maintain it, ie it needs a small uranium/plutonium starter in order to get and keep the reaction going.
No. Again, thorium is not fuel. It is breeder material. A breeder reactor using thorium needs higher reactivity to be critical, which necessitates being initially fueled with high enriched U or Pu. The amount is not small. The amount of feed fuel you need is more than enough for the feed itself to be a self sustaining reactor because the breeder material reduces reactivity. But once they begin breeding, turning Th-232 into U-233, the reactor can continue to operate without needing to be refueled. Again, the main advantage of thorium is that it is cheaper and more common than uranium.
Its main advantage being its easy to shut off, block the source and the reaction slows until it stops. It thus requires less safety features from a power reactor stand point.
No. Thorium breeder reactors work just the same as regular reactors. They are a self sustaining critical reactor just like uranium-fueled reactors. You cannot stop the chain reaction by blocking a source because the source is the fuel itself.
But to take thorium and put it into a car would be no less hazardous as the problem isn't the reaction itself, its getting hit or hitting other cars and obstacles which happens to millions of cars a year.
That's true of course. But a small reactor can be made pretty sturdy. You probably couldn't fit the rest of the components into a small car, but a large semi-truck sure.
QuantumPion
6,010
Fusion power is in use today all over the world. My son's new calculator is fusion powered! There is a huge fusion reactor in the center of our solar system, all we need to do is collect the free power.
All forms of energy in the universe are fusion based using this measure, including fission, the material for which was generated by fusion in a supernova. Calling every type of power fusion is pointless, all you are doing is removing the distinction between things which ought to be distinct.
Gibsons
12,530
35
What are the smallest operational reactors, and how big are they? I'd guess the smallest are in submarines?
QuantumPion
6,010
The smallest one I am aware of is the SNAP-10A which is a nuclear powered satellite. It is about the size of a microwave.
lakedude
2,778
529
All right I'll draw you a distinction. I'm talking about a currently running nuclear fusion reaction, not stored up energy from past events. I'm taking about a nearly idea reactor that is currently up and running a nice safe distance with zero nuclear waste issues. All you gotta do is put up collectors and collect the free energy.
Instead we are running around spending millions on terrestrial fusion which is not likely to ever be practical. They have been wasting my tax dollars my entire life and they have made zero progress. They have been shooting lasers at tiny targets for as long as I can remember. The lasers are getting bigger and better but as an energy source terrestrial fusion is just a pipe dream.
There was an article just the other day on terrestrial fusion claiming more power out than power in. What a load of crap! They are only counting the power used to run the lasers. Not all the power used to to construct the facility. Plus that power is just wasted anyhow. They are exactly nowhere on the ability to contain and collect power from a terrestrial fusion reaction.
Any practical source of energy needs to put out more energy than it took to produce said energy.
QuantumPion
6,010
I've never understood the opposition to fusion research. Way more money has been wasted on solar and wind subsidies and boondoggles than has ever been spent on fusion research. Way, WAY more. Your argument is completely baseless and irrational. As for solar power, at < 20% efficiency and < 15% capacity factor, I'd hardly call it ideal. And at 10x the cost, hardly free either. The idea that wind and solar can provide anything more than a small fraction of our energy needs, now that is a pipe dream.
lakedude
2,778
529
So what fraction of our energy needs are currently being supplied by terrestrial fusion? Let me help you answer that one, NONE!
As for Hydro, Solar and Wind, sure they are only a drop in the bucket but at least they are a drop and at least they all produce more energy than they took to make, except maybe some solar cells which do not.
Money spend on such endeavors is hardly wasted. With any forethought at all you can see that cheap fossil fuel's days are finite. We have no choice but to become sustainable and more efficient in the future. If terrestrial fusion had a snowball's chance I'd be all for it but such is not the case.
You seem like a bright person, you tell me the path for terrestrial fusion to become practical. I'm asking for something like: Well they have lasers going now, and containment is nearly solved by such and such, and they can keep the reaction going for more than a fraction of a second by such and such, etc.
In the computer industry you see progress year to year, terrestrial fusion not so much.
Gibsons
12,530
35
Just published in Nature. Not expecting this to change the world right now, but still shows some promise.
Fuel gain exceeding unity in an inertially confined fusion implosion
Ignition is needed to make fusion energy a viable alternative energy source, but has yet to be achieved1. A key step on the way to ignition is to have the energy generated through fusion reactions in an inertially confined fusion plasma exceed the amount of energy deposited into the deuterium–tritium fusion fuel and hotspot during the implosion process, resulting in a fuel gain greater than unity. Here we report the achievement of fusion fuel gains exceeding unity on the US National Ignition Facility using a ‘high-foot’ implosion method2, 3, which is a manipulation of the laser pulse shape in a way that reduces instability in the implosion. These experiments show an order-of-magnitude improvement in yield performance over past deuterium–tritium implosion experiments. We also see a significant contribution to the yield from &#945;-particle self-heating and evidence for the ‘bootstrapping’ required to accelerate the deuterium–tritium fusion burn to eventually ‘run away’ and ignite.
QuantumPion
6,010
Well as of not too long ago the fraction of our energy produced by solar power was zero too. Guess that means its a useless technology and a waste of money too then. Oh well, so much for your argument!
For your information, the purpose of inertial confinement fusion isn't to produce net power. It's more about basic research into plasma physics. The experiment which is expected to produce net power is ITER, which is currently being built and will go online in ~5 years or so.
So to you, spending 100's of billions of dollars on failed renewable energy schemes which can never produce power on a large scale is fine and dandy, but spending 1 billion over 10 years for the possibility of unlimited energy in the not too distant future is a monstrous waste of taxpayer dollars?
Since when did liberals care about wasting taxpayer dollars anyway? No, you and the other anti-fusion research kooks have some sort of agenda. The only thing I can think of is that you are luddites afraid of progress or something.
This is not P&N. Please leave the talk of liberals and the personal attacks there.
admin allisolm
lakedude
2,778
529
Way to keep it civil.
Look you know beans enough about me to call me a liberal or a kook or a luddite.
I'm all about cutting spending everywhere because we can't just continue to borrow money forever. This includes everything everyone in any party want to spend money on from the Military to Social Programs, from Domestic Farm Subsidies to Foreign Aid, from Pet Pork Projects to NASA. It isn't that all these things are bad, it is that we can't afford to keep wasting money.
Here is the first thing I found using Google to look up Fusion:
"Physicists have been pursuing the dream of fusion power for over half a century."
Yep, sounds about right.
Unlike terrestrial fusion we are producing many megawatts of wind, hydro and solar power right now.
oynaz
2,449
A pipe dream? The Danish government are aiming to make renewable energy provide a net 100% of the country's energy needs by 2050. Even today, wind power is providing more than 100% of needed electrical power on windy days (ie. power is being exported to the rest of Europe) . This December, renewable energy provided more than 50% of needed power overall (In Denmark, that is, but I believe France broke the 50% barrier as well).
Many other European countries, for instance Sweden, Germany and France, have similar goals and are seeing similar results, though I believe Denmark is the most ambitious.
Renewable energy as a major part of a country's energy needs is not a unicorn in the garden. It is happening right now in some of the world's most most powerhungry (per capita) economies.
As such, your claim that renewable energy cannot provide more than a small fraction of our energy needs is plainly wrong. It is not a matter of discussing in theory, or a matter of political observation. It is happening right now.
That does not mean that I do not agree with you that money spent on fusion research is very well spent. Fundamental science studies, overall, always pay off, even though it might not be in the way expected. The possible gains of a working fusion reactor is so large that a even an investment of tens of billions is very small in comparison.
QuantumPion
6,010
Denmark has a small population with a lot of coastline so that is one area where wind power is ideal. That being said, they only produce 1/3 of their electric needs from wind, and they are totally reliant on backup power from Germany which is primarily coal. Furthermore, they have the highest electricity costs in Europe. The total wind energy produced by Denmark under ideal circumstances is on the order of the output of one nuclear reactor. Denmark's situation cannot be extrapolated to the rest of the world.
You can't beat the laws of thermodynamics or economics. Having 100% of your energy produced by renewables is a nice WISH, but it is not physically possible at the rate we currently use energy. If you want to rely 100% on renewable power, your standard of living will decrease by a factor of 5-10 i.e. everything you buy will cost 5-10x more while your income stays the same.
And FYI France produces 75% of their power from nuclear, 10% fossil fuels, and the rest mostly hydro.
yhelothar
18,409
39
The Stirling engine can operate very close to the carnot cycle, which is the optimum efficiency at converting thermal energy to mechanical energy.
oynaz
2,449
So what? Hydro power is ideal in norway, solar power is ideal in Egypt, biofuels are ideal in Brazil. Renewable power production needs to be tailored to the circumstances. Nothing new here.
ONLY 1/3? You just claimed that renewable energy would only ever amount to a small fraction, and next post you call 1/3 "only". You are moving the goalposts.
Not true. Denmark is self-reliant on power. It is true. however, that Denmark, Sweden, Norway, Northern Germany and I believe the Netherlands have linked their power grid and relies on each other. Both for backup, and to better take advantage of the varying costs of energy production.
True. No one claimed that doing major changes to the most important part of your infrastructure came cheap.
Which is enough to cover the entire country's needs. More than "a small fraction", yes?
That's gobbledygook. Which laws of thermodynamics and economics are renewable energy breaking, exactly?
How do you know this? But OK, I concur that 100% is impractical. However, 80% or 90% with traditional energy production as backup will also have a very positive effect on the environment, while lessening the dependency on the generally volatile fossil fuel producing countries, and avoiding the issues of nuclear power.
15% renewable energy, you say? More than a "small fraction". Also, that fact rather disproves your point about extrapolating the situation in Denmark to the rest of the world.
I never made the claim that all the world can go with 100% renewable energy. I only claimed that "The idea that wind and solar can provide anything more than a small fraction of our energy needs, now that is a pipe dream." is false.
QuantumPion
6,010
I'm considering hydro separately from wind and solar because hydro is an ideal source of energy but is limited to locations where it is available. Yes, 15% of France's energy is "renewable" but 14% of that is hydro and there's not really any room for expansion.
While it's true Denmark does produce a large percentage of its electricity from wind, it is an exception that can't be extrapolated to the rest of the world. It is like claiming since Las Vegas gets 100% of its power from renewables (Hoover Dam) the whole world can be 100% renewable. My point is in certain locations wind power can be useful, but the total energy output of all the places wind can be effectively harnessed is tiny compared to the amount of energy we use on a whole. Solar and wind will never be able to produce more than ~5% of the world's energy needs.
This has gone off topic far enough, if you want to continue discussing it start a new thread in P&N.
lakedude
2,778
529
So getting back on topic, I submit that a solar powered electric car is fusion powered...
lakedude
2,778
529
Further there is no point in carrying a reactor around with you everywhere you go. Hook an electric car up to a grid powered by a nuke plant.
AD5MB
shipyard workers have twice the cancer rate of the general population.
workers on nuke subs have 6 times the cancer rate of the general population.
workers who refuel nuke subs have 12 times the cancer rate of the general population.
per the union at the shipyard I worked at in 1978
QuantumPion
6,010
Yeah and being the child of someone who used to work at a company that was originally owned by another company which used to use asbestos causes mesothelioma too. The TV lawyers said so so it must be true.
_Rick_
3,982
74
The biggest issue with mobile nuclear power is the cooling requirements.
Air cooling nuclear reactors directly is a mess. Even air-cooling the primary coolant loop isn't done in commercial reactors, because the coolant gets activated as it circulates through the core.
In nautical applications, you can use seawater cooling very efficiently. But even then, nuclear surface ships at times have difficulties crossing the equator, because the intake water temperatures are problematic. Most commercial plants either use evaporation cooling or exhaust the warm water directly into a river or the sea. That's impossible in most mobile applications, because there's no body of water in proximity. Alternatively you would have to frequently replenish a water tank - much like steam engines in the past.
RNG's are woefully ineffective and have high material costs and shielding requirements. Useful if you are on a spacecraft traveling away from the sun, otherwise there are more efficient alternative fuels.
Outside of nautical applications, the only kind of mobile nuclear reactor that I could imagine, would be a vast freight train. A direct train connection between China and Europe might be the only way this could be economically interesting, if it could be made cheaper, faster and more reliable than ships going through Suez or around the Cape of good hope.
But even then it would probably be cheaper to electrify the whole thing and use electrical power, than to have a nuclear locomotive. And the fact that it couldn't be gauge-compatible with any existing train, and it would have to go through some of the most arid parts of the world (Siberia/Mongolia) basically render it just another complete pipe dream.
But that's the thing with nuclear: if you're going to use it, you're instantly limited to gigantic use cases, as the economies of scale are brutal for nuclear propulsion.
QuantumPion
6,010
No, the biggest issue is shielding requirements. If a regular internal combustion engine for a car can reject heat with a water-cooled radiator, so could a nuclear reactor of the same size. The efficiency of both is around the same.
No, primary coolant loop can not contaminate the secondary loop. They are separate, that's the whole point. There are gas cooled power reactors around and they work just fine.
No. Nautical reactors (and power reactors that use a body of water for heat sink) are less efficient when the water is warmer but there is nothing preventing them from operating normally.
No, reactors can be air cooled just fine. Air cooling is less efficient but the reactor power is far less than a nautical or power reactor.
A nuclear powered freight train is most definately possible using existing train sizes and could replace any domestic line. It's true though that it would be safer to just make trains electric driven from a regular nuclear power plant.
