polarmystery
- Aug 21, 2005
- 3,888
- 8
- 81
Turbines use .55 LB/HP/hr of fuel.Interesting, still using piston and crank arrangement, I thought turbines were the norm for that type of (large) power needed to propel an 700+ foot vessel..
Reminded me of this for some reason...
Also, I can't believe that's how those ships are launched! When I saw the first video, I thought something had gone wrong and it was sliding toward the water by mistake. I guess as long as nothing binds up, it's a sound way of doing things. I would have thought there was some sort of ramp with rollers or something which would allow ships that big to go bow-first into the water. Cool vids.
The ship in the first video looks like it hardly has any draft at all. Hard to imaging that it would be very stable in rough seas.
Imagine four of those and that's our engine room!
I'd be more interested in seeing the engine room than the rest of the ship.
In Miami in particular the waves coming in on a perfectly calm day are impressive. I'd imagine at 15 knots there would be some flooding on the streets
The system that manages this can be completely automated and is quite complex.
Piston engine diesels like that Wartsila in the pictures use about half that,
.278LB/HP/HR
The turbine has the highest output per pound of engine, but a big ship is not adversely effected by the added weight. Only high performance military ships can afford the fuel consumption of a turbine.
That's because she's empty. When loaded the bow bulb is submerged and there's plenty below the water line. When they don't have cargo they pump water into ballast tanks to provide draft.
Regulations require monitoring of water as well due to possible spread of undesirable organisms. If water is used for ballast in a port with a known hostile organism it cannot be released in a distant port with waters foreign to said life forms. Of course things (mainly in the past before technology existed to monitor/control them!) do slip through. This is how insects can get across the pond, for example.
environmental regulations on the coal
IIRC it has to do with environmental regulations on the coal to power a turbine engined ship.
A lot of people say that except the ones that work down there. To them the most interesting part of the ship is the bar!![]()
I can't recall anything like that in recent memory. Of more concern is steady easterlies which erode the beach and deposit it on the street. It takes a good day long set of head-high or greater sets to seriously impinge on the streets. Not too sure on the causeways though, I think they tend to be higher than they seem.
Yup. I'm a couple tiers below that level doing luxury yachts. We automate fuel valves/pumps, bilges/trim ballast tanks, report doors, engine alarms, etc.
It always amazed me that the larger vessels get so unstable when unloaded that they'd rather take the massive hit in fuel economy than run empty.
I was also shocked that the load shedding done onboard (at least on our vessels) is by heating seawater.
What kind of stabilizers work on a boat that uses azipods Ruby? I'd imagine its completely different than the zero-speeds often used on the boats on which I work.
Didn't that ship carrying all those Mazdas tip over a few years ago because they were changing out the water in the ballast tanks before it came into US waters for that reason? If I remember right the system to keep the ballast balanced malfunctioned and they vented all the water on one side.
Link to story about the ship
Car carrier tips
She looks a bit heavy in the back.![]()
I didn't say I want to work there, just see it!![]()
things can get closer to flooding if someone would speed through.
Big issue the yachts always seem to have whilst docked - some jackass in a 80ft sunseeker goes blasting by at 20kts and the wake screws up the fenders. Do it big enough, or enough times and they'll ask the next bridge tender to help identify the vessel and bring the owner into court for a new paint job / body work.
