I'm talking about TVs, stereos, voices, passing cars, trains, dogs, cats, people fucking, and other normal everyday noises, not going 20 miles out of town to the fucking airport to see if planes are really as loud as they say.
"Of a certain volume". you said it yourself.
The guy is "in his 60s", so I think I can safely assume that his home entertainment center looks more like this:
than this:
My point is that this guy actually MOVED three times due to what he considers excessive noise. Would you move even once? I doubt it. I doubt it for most people. So if he is that upset by noise that he has actually packed all his shit and moved three times, is it not unreasonable to question HIS TOLERANCE to noise?
Nope, don't care. At three times I am compelled to start finding the fault is yours.
I am also coming from this perspective: noise only hurts and bothers those who choose to be hurt and bothered by it (like name calling). Don't pay attention.
Also, everyone that I have ever seen complain about noise is either a doucherocket, old, or both.
Obvious troll is obvious.
The guy has a 50" or so plasma, not a little old black and white TV. I've also been to plenty of concerts and even worked in a car wash earlier in life, so as I mentioned previously I'm partially deaf myself. The previous noise issues had to do typically with neighbors fighting violently non-stop every day, with numerous times where the cops were called on them.
Satelite?
Fixed:
OK, I have to ask... how does shaving cream "fix" the satellite dish? You put the stuff on the LNB, or what?
What do you mean he got the idea after you did the subwoofer trick? Did he suddenly turn down his television set?
Yeah - basically I pointed the subwoofer "opening" directly at the floor, turned it up loud, and popped in God of War3 on the PS3. There are constant explosions, yelling, etc. in the game. I only played for about ten minutes before I put it on pause and noticed his TV was turned down.![]()
What if got he it as a result of one of the wars or something?
Get a decent motor like a 56 frame 1/2hp or greater and bolt it down TIGHT to your floor. Securely attach something unbalanced to the shaft. Testing behind a concrete wall is suggested with a 3450 RPM motor first!
Essentially what you've made is a REALLY large vibrator - no different than what makes a cell phone vibrate but really large. So instead of making the casing of a phone vibrate the frame of the building vibrates! A quick blip or two of the motor is all that's needed. Very simple and will run on any typical circuit and will produce terrifying results only matched by really large professional amps and reinforcement type subs that both won't fit through your doors nor run on 120VAC household current.![]()
I think you are oversensitive too, and quite possibly nuts. You seriously did all that?
You told a guy in a letter that moving was a great idea for him, and nothing happened? Shocker!
You called the police about noise in NYC and nothing happened? Shocker!
You told your landlord in NYC about it and nothing happened? Shocker!
You were wasting taxpayer money. Guess why nothing happened? Because you're oversensitive and most people could give a shit.
Light sleeper, not my problem.
ADHD, not my problem.
I made a point about how a guy moved 3 times due to noise (that probably never exceeded 70db) and you jumped on me with examples of planes. You can see I just brim with sympathy.
soo thats what keeps you in a good mood..:awe:
