- Oct 28, 1999
- 62,484
- 8,345
- 126
Originally posted by: Zstream
I do not understand this stuff... Why do people always "Well I have a job still" quote this crap. If you are good at what you do a MAKE a difference then people will recognize it. If you work at a helpdesk, fast food joint, construction or any place that requires low skill labor then it is a different story.
I am just sick and tired of people thinking this is the way it is. I would never ever think to myself that I am lucky, in fact it is the other way. The company should be lucky to have you. Obviously for those not making a difference and just doing what is needed will not feel this way.
/rant
Because in a number of structured larger corporations raises are a clearly defined, budgeted expense. They are nothing more than COL adjustments, not a true raise. If you want to make any real increases in income then you either change positions or employers. Staying in the same role, regardless of how well you perform is going to get you nothing.
In these types of companies everyone gets 2%-5% regardless of merit. When the budget gets tight and the company needs to trim some costs, what would you rather give up? Your job, or your modest 2%5% raise? My company gave up on raises. I'd rathe that than shitcan a couple hundred people.
