Originally posted by: bunnyfubbles
Not ideal, but it can at least help reduce the amount of times you have to go to change the volume...
http://en.wikipedia.org/wiki/Replaygain
No!  Compression TOASTS the life for EVERYONE!  If people don't like quiet recordings then buy a receiver/preamp/head unit with a compressor, night feature, etc.
This topic has been beaten to death.
Generally, DVD's don't have the dynamic range compressed so why should CD's?  Especially in 2007!  PWM amp tech makes it possible to have VERY powerful amplifiers in small boxies. (1U amps >10kW exist in pro audio!)  If people want to hear every part of a song at low volume - great!  The playback equipment should have the compressor.  Once a recording is torched, it's done.  No amount of post processing will fix it.  It's like a footprint on the sidewalk.
There are still good recordings out there but most pop stuff going to CD is torched big time.  I have heard stuff before torching and even though it may not be my preferred genre it's actually enjoyable to listen to because it sounds LIVE and jams.  But the same thing on CD for public release is just awful.
Bit rate of an MP3 is not nearly as important as the compressor that makes it.  I've heard 320kbps files that sound like dog poo and 128kbps files that were quite listenable - again because of the codec.  The superior ones make 320kbps sound very good - very close to CD quality and only easily discernible with certain program material from the original.  But that's another topic that has been beaten to death.
