- Aug 28, 2006
- 262
- 7
- 81
Nice deal. Personally I'd use up what you have (wheels,crank) and then upgrade as they get worn out. At minimum wait until your chain is worn then replace the crank, chain, cassette. When you do that you can really find the gearing that best suits you and upgrade to higher end stuff.
I want to slap a compact crank on there as soon as possible as I find myself getting bogged down on steep climbs. I want to be maintaining 80-100rpm cadence going up climbs, and the current crank (53x39) is too heavy for my legs to push around on the big hills. I also want to switch to a shorter crank arm (170mm) to better suit my height/inseam.
Yup.
I'd actually focus on ergonomics first of all.
Adjustments to stem length, handlebar width, saddle shape/angle/position are probably some of the most noticeable modifications.
I'll be getting a professional fitting done as soon as possible for maximum efficiency and comfort on the bike. They are a bit expensive ($150-200 for a decent fitting) but completely worth it from what I've been told. I've dialed in a decent baseline on the bike now (as pictured), but I can tell stem length needs to be adjusted as my hands comfortably rest on the bars just short of the hoods (and it feels like I need to reach a bit to actually sit on the hoods). I also have a small curve in my upper back on the bike which can probably be sorted with a small saddle height or fore/aft adjustment. The thing is, the range of adjustment needed to attain a proper fit is too fine to accurately measure using at home, DIY methods-hence the need to get a fitting done.
