New Build First One. I would love any thoughts or help.
mnewsham
14,539
428
Also this might interest you if you can wait a bit to buy. The EVGA 2win it is a dual GTX 460 GPU that supports 4 displays at once, 3 DVI and one mini HDMI. All you would need for that is 3 monitors with DVI/VGA (vga with a small adapter) and one HDMI monitor and this cable.
mnewsham
14,539
428
didnt know that either!
so 2 DP to DVI adapters go to my 22"'s
DVI direct to the 20" in the booth.
and the other DVI to vga reference monitor
DONE!
Do the monitors with HDMI also have DVI? if so then just use DVI to DP ;)
bradnewman
111
yeah my 2 main monitors (the 22's) have 3 connection types - HDMI, DVI and VGA
the 20" in the booth is just DVI and VGA
and then I have one Older VGA
